jerryneal Posted October 21, 2016 Report Share Posted October 21, 2016 I turned on the furnace for the first time this season and the air conditioner turned on as well. Through the Summer, the air conditioner ran only on its setting. I had some roof repairs this Spring and the roof unit was pulled and replaced. Is it possible to miswire the air conditioner to cause this problem? Jerry and Joan 2014 Ford F350 with 6.7 turbo, TrailerSaver 2014 40' Heartland Gateway Fifth wheel iLoveRVlife.com Link to comment Share on other sites More sharing options...
Ronbo Posted October 21, 2016 Report Share Posted October 21, 2016 Is it a heat pump? Ron C. 2013 Dynamax Trilogy 3850 D3 2000 Kenworth T2000 Optimus Prime Link to comment Share on other sites More sharing options...
orbiker Posted October 21, 2016 Report Share Posted October 21, 2016 Try setting the fan setting to auto. Link to comment Share on other sites More sharing options...
Chief 62 Posted October 21, 2016 Report Share Posted October 21, 2016 Pop the front of the thermostate off and spray some electrical contact cleaner on the micro switch that controls the setting and work it back and forth a couple of times. It may just be dirty contacts. Gary & Penny 2015 Lance 1172 2005 Chevy 3500 2013 Bass Tracker 190 Pro Team Link to comment Share on other sites More sharing options...
Kirk W Posted October 21, 2016 Report Share Posted October 21, 2016 We don't really have much to go on as it would help to know the kind of air conditioner (make & model), and the make/model of the thermostat. Also what furnace you have. I would not start spraying chemicals into things until I knew more about what you have and if you do that, make sure you have the power to it turned off. ... I had some roof repairs this Spring and the roof unit was pulled and replaced. Is it possible to miswire the air conditioner to cause this problem? Yes, that is possible, but it is difficult to know just what may have happened. The thermostat control circuitry passes through the air conditioner and then to the furnace when the same one controls both units. Most RV furnaces have a thermostat line that goes to a switch or set of contacts which is then either open or closed, with the closed position causing the furnace to turn on. In many thermostats there is just a set of contacts that open or close based upon the selected temperature, and the circuit inside of the air conditioner then sends the signal from the thermostat either to the air conditioner to make it turn on when temperature rises, or to the furnace causing it to turn on when temperature falls. For both to turn on at the same time would be a control function since a/c starts with a rising temperature and the furnace should start with a falling temperature. There are thermostats today that have more of the control function in them, while the more simple ones are only a set of temperature controlled contacts. I suspect that yours is one of the more intelligent thermostats with a solid state control board and multiple outputs. It could have just two wires out if the most simple of thermostats, or it may use a telephone cable type of output or some other multi-wire cable, depending upon make and model. Good travelin !...............KirkFull-time 11+ years...... Now seasonal travelers.Kirk & Pam's Great RV Adventure Link to comment Share on other sites More sharing options...
weaverworks Posted October 22, 2016 Report Share Posted October 22, 2016 I think you need to investigate the above question..."is it a heat pump/air conditioner." On my Mach 8, if you have the thermostat set more than 5 degrees above room temperature, the furnace will come on with the heat pump/AC. For just the heat pump, you must set thermostat within that 5 degree setting. For just furnace you set on "electric heat." Not sure what you have but worth checking. Paul & Marsha WeaverBella our cat2008 Carriage Cameo 35' SB32010 Ford F350 DRWBlog: http://wheresweaver.blogspot.comSKP# 102686 Link to comment Share on other sites More sharing options...
Ray,IN Posted October 22, 2016 Report Share Posted October 22, 2016 Kirk is right, not enough information to even make an EWAG. Provide make/model of RV, details of new roof units, details of new thermostat, etc. if you want anyone to offer a cogent reply. To answer your question; yes it is possible to mis-wire things. 2000 Winnebago Ultimate Freedom USQ40JD, ISC 8.3 Cummins 350, Spartan MM Chassis. USA IN 1SG retired;Good Sam Life member,FMCA ." And so, my fellow Americans: ask not what your country can do for you--ask what you can do for your country. John F. Kennedy 20 Jan 1961 Link to comment Share on other sites More sharing options...
57becky Posted October 22, 2016 Report Share Posted October 22, 2016 If you have a Dometic CCCII thermostat, like what was already said, you must have the fan switch set to AUTO. If you have it set to LO, MED, or HIGH, the A/C fan will run, but the A/C compressor does not run. Link to comment Share on other sites More sharing options...
jerryneal Posted October 24, 2016 Author Report Share Posted October 24, 2016 If you have a Dometic CCCII thermostat, like what was already said, you must have the fan switch set to AUTO. If you have it set to LO, MED, or HIGH, the A/C fan will run, but the A/C compressor does not run. Well didn't I just have a Homer Simpson moment. I've had the 5th wheel for over 2 years and guess the thermostat was place on AUTO for the first time. Set for HIGH and that fixed the problem. One of those tips you don't find in the manual. Many thanks. Jerry and Joan 2014 Ford F350 with 6.7 turbo, TrailerSaver 2014 40' Heartland Gateway Fifth wheel iLoveRVlife.com Link to comment Share on other sites More sharing options...
