JRP Posted August 31, 2016 Report Share Posted August 31, 2016 I had my first Motorhome front tire blowout last Friday while going 60 MPH. Sure was glad I had previously watched this video that others had posted here over the years, Coach-Net sent me a good big rig tire service and had me back on the road in an hour and half, using my unmounted spare. The question I have for the group is, what product or process do you recommend for getting the heavy black rubber tire deposits off my previously shiny polished alum rim. When the tire blew and shreaded, it left lots of black tire rubber ground into the surface of my 22.5" Accuride polished alum rim. My normal cleaning products don't seem to be working on it. Link to comment Share on other sites More sharing options...
ronmon Posted August 31, 2016 Report Share Posted August 31, 2016 Just for grins, try WD40...might do it & wont hurt. Ron Link to comment Share on other sites More sharing options...
rambler62 Posted August 31, 2016 Report Share Posted August 31, 2016 I have used laquer thinner or acetone in the past. If that does not work andyou want to get really serious xylene. Other than that it is rebuff. Link to comment Share on other sites More sharing options...
Ray,IN Posted August 31, 2016 Report Share Posted August 31, 2016 Take care what you use, some chemicals will remove the finish sealer, some rim mfgrs. use lacquer. Some rims do not have a sealer coating, that's the ones that must be polished to restore the shine. Mothers R3 has good reviews. Link to comment Share on other sites More sharing options...
Newt Posted September 1, 2016 Report Share Posted September 1, 2016 I saw a trailer the other day with aluminum wheel repair graphics. https://www.dentwizard.com/exterior-repair/wheel-repair.aspx http://www.awrswheelrepair.com/ http://www.sttc.com/services/aluminum-wheel-refinishing/ Newt Link to comment Share on other sites More sharing options...
fly2low Posted September 2, 2016 Report Share Posted September 2, 2016 Mothers R3 WD40 Too strong and you could hurt the wheel OR rotate it to the inside of the rear tandems. Out of sight Link to comment Share on other sites More sharing options...
ronmon Posted September 2, 2016 Report Share Posted September 2, 2016 I don't think a front MH wheel will fit on the rear. Typically the inside dual is a steel wheel & the outer one is deep dished. Ron Link to comment Share on other sites More sharing options...
fly2low Posted September 5, 2016 Report Share Posted September 5, 2016 my rig has six identical polished aluminum wheels did not know someone would not have all the same Link to comment Share on other sites More sharing options...
JRP Posted September 5, 2016 Author Report Share Posted September 5, 2016 No one locally had the Mothers R3 on the shelf, so I didnt get to try that product. WD40 didnt seem to help. The local auto parts store had a product named "Goo Gone" that worked well, but only after I used thinner on the thickest deposits. My wheels do have a protective coating over the polished alum and I didn't want to use thinner directly on that. It took several sessions of applying the Goo Gone, letting it soak in, and then rubbing it off. its looking like new again, thanks for the input. Next it needs a small fiberglass patch where the spinning flat tire broke off a piece of the finished lip of the wheel well. Yes, my front wheel is completely different than the rear. The front bulges out around the hub and the outer rear has a deep set back in around the hub. Freightliner Chassis with typical big rig wheels. Link to comment Share on other sites More sharing options...
fly2low Posted September 6, 2016 Report Share Posted September 6, 2016 mine is also a freightliner big rig wheels on mine, the front and rear are identical, convex out on the front, concave in on the back. Suspect yours are the same That is why one spare is good for all positions Link to comment Share on other sites More sharing options...
