Alie&Jim's Carrilite Posted June 17, 2016 Report Share Posted June 17, 2016 Symptoms- Key doesn't always turn in the cylinder. Usually, end up doing a wiggle on the key and moving the steering wheel enough to turn the wheels to get it to unlock. Its a B#@*h when the wheels are against a curb. Is this a DIY replacement or a trip to the Volvo guys? What's the chance that a cylinder can be keyed to our existing key so we don't end up 1 key for the doors, and 1 for the ignition? Alie & Jim + 8 paws 2017 DRV Memphis BART- 1998 Volvo 610 Lil'ole 6cyl Cummins Link to comment Share on other sites More sharing options...
Hewhoknowslittle Posted June 17, 2016 Report Share Posted June 17, 2016 Symptoms- Key doesn't always turn in the cylinder. Usually, end up doing a wiggle on the key and moving the steering wheel enough to turn the wheels to get it to unlock. Its a B#@*h when the wheels are against a curb. Is this a DIY replacement or a trip to the Volvo guys? What's the chance that a cylinder can be keyed to our existing key so we don't end up 1 key for the doors, and 1 for the ignition? Jim, Mine used to do this, went to the dealer and ordered a new key, works perfect now, so had some spares made. If you see any wear on your key you might try this. Roger Link to comment Share on other sites More sharing options...
Steve from SoCal Posted June 17, 2016 Report Share Posted June 17, 2016 Can't speak for Volvo but, Mercedes mechanical ignition switches DO fail and it is a real PIA to drill them out. It is much easier to replace the cylinder before it fails hard. The cylinder should be available from Volvo, keyed to your truck. You should be able to remove and replace the cylinder yourself if you can turn it to the release position and use the removal device required. The removal device is usually a round or flat that can be shop made. Steve 2005 Peterbilt 387-112 Baby Cat 9 speed U-shift 1996/2016 remod Teton Royal Atlanta 1996 Kentucky 48 single drop stacker garage project Pulls like a train, sounds like a plane....faster than a Cheetah sniffin cocaine. Link to comment Share on other sites More sharing options...
Alie&Jim's Carrilite Posted June 17, 2016 Author Report Share Posted June 17, 2016 Roger- This happens with both keys.... equally worn I don't know. Steve- Back in past vehicles, I remember a simple screwdriver starting both a jeep and an old International truck. Alie & Jim + 8 paws 2017 DRV Memphis BART- 1998 Volvo 610 Lil'ole 6cyl Cummins Link to comment Share on other sites More sharing options...
beyerjf Posted June 18, 2016 Report Share Posted June 18, 2016 I just went through this with my Freightliner. The ignition switch, not the lock cylinder was the problem. It would not turn unless wiggled, or worse, would not return from the start position, keeping the starter engaged after the engine started. The ignition switch without lock cylinder was $12.65. In order to get the lock cylinder, you had to order all the lock cylinders for the truck (3- both doors and the ignition) which were get this $155. I tried to pop the lock out and turn the switch with a screwdriver, but alas the engineers thought of that and had a small round recessed hole which defeated that attempt. Freightliner had the ignition switch on the shelf, very simple part, probably same for at least 30 years. Key in place, depress the retaining ring on side, pop out the old lock cylinder, and then install the old lock cylinder in the new ignition switch. Jeff Beyer temporarily retired from Trailer Transit 2000 Freightliner Argosy Cabover 2008 Work and Play 34FK Homebase NW Indiana, no longer full time Link to comment Share on other sites More sharing options...
RandyA Posted June 21, 2016 Report Share Posted June 21, 2016 Remove the panel on the bottom of the steering column using a T25 Torx screwdriver. Oil the cylinder and lock with graphite based lock oil or another thin oil like sewing machine oil or even WD-40. If you try this you may not need to replace anything. Keys get dirty, dirt goes in key cylinder eventually causing problems like you described. Randy, Nancy and Oscar "The Great White" - 2004 Volvo VNL670, D12, 10-speed, converted to single axle pulling a Keystone Cambridge 5th wheel, 40', 4 slides and about 19,000# with empty tanks. ARS - WB4BZX, Electrical Engineer, Master Electrician, D.Ed., Professor Emeritus - Happily Retired! Link to comment Share on other sites More sharing options...
Alie&Jim's Carrilite Posted July 8, 2016 Author Report Share Posted July 8, 2016 Just an update I found a product recommended by a local locksmith called Lock-Ease. It's a graphite mix that lubricates and helps clean the lock internals. What I did was remove the cover on the bottom of the column, sprayed a compressed air can, like the ones you use on a keyboard, with the straw down in the lock itself. The amount of dust that blew out was impressive. Next was several shots of the Lock-Ease. More dirt and grime seeped out of the tiny hole in the lock assembly. Blew the lock out again and resprayed the lock again with Lock-Ease. Cleaned both keys with an old toothbrush. The lock hasn't stuck in 2 weeks. It feels different when turning the key as well. Before the key rotated in the cylinder what felt to be smoothly, now it turns to each detent position with a firmer feel. Before you didn't have to push the lock cylinder in to turn the key to the first position, now you do like a new lock would. So with luck, this cleaning will last another 3-400000 miles before needing some more attention. Alie & Jim + 8 paws 2017 DRV Memphis BART- 1998 Volvo 610 Lil'ole 6cyl Cummins Link to comment Share on other sites More sharing options...
Alie&Jim's Carrilite Posted October 20, 2016 Author Report Share Posted October 20, 2016 New update- We ended up having to replace the entire ignition lock cylinder. The key would not turn enough to be able to push the indent pin to remove the mechanism. So I removed the top cover of the column, removed the 2 Allen bolts, unplugged the wiring, and took the whole assembly to the dealer. New one was $171 plus shipping. This was the cheapest and fastest option. For a longer wait time and $40-50 more, they would key a cylinder to our existing door locks. I can live with 2 keys. Alie & Jim + 8 paws 2017 DRV Memphis BART- 1998 Volvo 610 Lil'ole 6cyl Cummins Link to comment Share on other sites More sharing options...
