4x4ff Posted April 17, 2016 Report Share Posted April 17, 2016 I am getting ready to install an inverter in my 5er. Sometimes we leave the 5er at our campsite and it may be 6 months before we are able to get back to it. I want to install the inverter to run the residential fridge in it. Anyway.....I was thinking when I install it would it be a good idea to put this http://www.amazon.com/gp/product/B005DUUL9W/ref=pd_luc_rh_bxgy_01_04_t_img_lh?ie=UTF8&psc=1 in between the battery and the inverter? The switch is rated for 275 amps. That way if I am storing it for a while I KNOW I don't have to worry about the inverter messing up (even though it will be switched off). Maybe I am just over analysing it. Steve Link to comment Share on other sites More sharing options...
Chad Heiser Posted April 17, 2016 Report Share Posted April 17, 2016 I have a switch similar to that, but with higher amp ratings between my batteries and all loads (including the inverter). I did it for two reasons. One was long term storage, like you are talking about and the other was for system maintenance if needed. I wanted to be able to disconnect power from everything down stream of the battery bank when I needed to work on something. I used this one: [http://www.amazon.com/Blue-Sea-Battery-Disconnect-Amperes/dp/B014N35WJI/ref=sr_1_2?s=automotive&ie=UTF8&qid=1460871463&sr=1-2&keywords=Blue+sea+3000 but I have a large battery bank (8 six volt batteries in series /parallel at a little over 900 amp hours). Link to comment Share on other sites More sharing options...
skp51443 Posted April 17, 2016 Report Share Posted April 17, 2016 For storage you want the switch to disconnect all the loads from the battery, not just the inverter. So many RV devices use a trickle of power that your batteries will be flat when you get back to the RV unless you kill all the drains. We usually just lifted the negative battery post and opened the breakers between the panels and the controller, that left us with no active electronics to worry about and minimal battery water use. Link to comment Share on other sites More sharing options...
4x4ff Posted April 17, 2016 Author Report Share Posted April 17, 2016 I already have a battery disconnect for the rest of the 5er. This will just cut the current to the inverter. Link to comment Share on other sites More sharing options...
