rhianna Posted January 2, 2016 Report Share Posted January 2, 2016 A while ago I read a string about Adblock Plus to help save data usage. I downloaded the program and it worked beautifully! My DH tried to download the program and it would not work. Does anyone know what may be the problem? Link to comment Share on other sites More sharing options...
wildmandmc Posted January 3, 2016 Report Share Posted January 3, 2016 Did it install, also depending on what antivirus you are using, that could block it or windows itself could block it. control panel, windows firewall, then click allow programs thru windows firewall, select adblocker, click apply/ok then try to open it. Link to comment Share on other sites More sharing options...
TheDuke Posted January 3, 2016 Report Share Posted January 3, 2016 Copy it to a thrumb drive on the working computer and install from there. This wont help with the problem,though. Link to comment Share on other sites More sharing options...
docj Posted January 3, 2016 Report Share Posted January 3, 2016 If you're using Chrome, for example, you don't download anything. You go to Settings/Extensions/Add extension. You then search for the extension you want to add and click on it. I think the procedure for Firefox is roughly the same. Link to comment Share on other sites More sharing options...
skp51443 Posted January 3, 2016 Report Share Posted January 3, 2016 Did you do the setup and install filter lists or are you manually adding filters? Link to comment Share on other sites More sharing options...
rhianna Posted January 5, 2016 Author Report Share Posted January 5, 2016 Well, I tried the firewall process and couldn't find Adblock even in the list of programs (they call them apps). Don't have any filters that have been installed by us. Will try to download and save then install and see what happens then. Internet not real good here in Quartzsite this year. Thanks for all your Link to comment Share on other sites More sharing options...
RV_ Posted January 6, 2016 Report Share Posted January 6, 2016 Are you both using Windows 10? Link to comment Share on other sites More sharing options...
wildmandmc Posted January 6, 2016 Report Share Posted January 6, 2016 then disable your antivirus program for 1 hr. then try to install it. an make sure if your on windows 10 that version of adblock is compatiable with win 10. might be driver is not built for it yet. but like one poster said might just have to enable it. start, control panel, internet options, 4th tab :"manage add on's. or chrome use instructions given above. Link to comment Share on other sites More sharing options...
docj Posted January 6, 2016 Report Share Posted January 6, 2016 If your husband is using Microsoft Edge as a browser with Windows 10, the AdBlock Plus website clearly states that at this time the app doesn't yet work with Edge. I just tried it and that's what was displayed on my screen. I don't normally use Edge but I did so just to check on this. Link to comment Share on other sites More sharing options...
