Mihaka Posted December 12, 2015 Report Share Posted December 12, 2015 Greetings, I have a 2006 Winnebago E450 Outlook 26A. Behind the emergency brake against the wall are some wires that have been terminated with no connection. I tried looking in the wiring diagram, but I cannot seem to find these. White/Red Grey/Red Dark Blue or purple Orange connected to yellow White/Green White/Light Blue Any information or guidance would be greatly appreciated. Link to comment Share on other sites More sharing options...
Al F Posted December 12, 2015 Report Share Posted December 12, 2015 Are you having a problem, or are you just curious? Just a guess, but wiring for a trailer brake are frequently placed in the area you mention. Also are you looking at a wiring diagram from Winnebago, or a wiring diagram for a Ford E450 van? I would be surprised if the Winnebago diagram included the Ford Van wiring. Link to comment Share on other sites More sharing options...
Sehc Posted December 14, 2015 Report Share Posted December 14, 2015 Do they have a connector plug at the end? Could be a diagnostic plug in port. Link to comment Share on other sites More sharing options...
Ronbo Posted December 14, 2015 Report Share Posted December 14, 2015 Sounds like trailer brake hook up wires Link to comment Share on other sites More sharing options...
evolvingpowercat Posted December 30, 2015 Report Share Posted December 30, 2015 If they are yellow Winnebago wires they will have a letter code printed on them. If any of them are white along with Winnebago Yellow then white is what Winnebago always uses for chassis ground. You can get the wiring letter codes off the Winnebago customer support web site. If they are not yellow Winnebago wires with letter codes then they are Ford F450 OEM Chassis wires. They provide 4 wires off fuse positions that coach builders can get chassis battery power on, Winnebago may not use all 4. The other possibility is what Rondo says, that they could be connections to add a controller for electric trailer brakes. Link to comment Share on other sites More sharing options...
