alan0043 Posted December 7, 2015 Report Share Posted December 7, 2015 Hi Everyone, I have a feeling that this question has been answered before. But I have not had any luck finding what I need. I did a search in the resource guide with no luck. I need to find a fitting that is 90* elbow. I do not what to bend the line to make the 90*. The line is going to coming up thru the floor at the rear of the cab and go to the front of the cab. This line is going to be used for the air hitch. What type of fitting would be best ? Do I use a standard fitting ( a fitting that you need to push the ring to release the line) or is it better to get a fitting what uses a ferrule. I can remember reading something about fittings having the word DOT on them. Do I need to look for this word on the fittings that I want to use ? What would be my best option ? I am looking for opinions, Al Link to comment Share on other sites More sharing options...
RickW Posted December 7, 2015 Report Share Posted December 7, 2015 Personally I prefer to replace fittings with one that does use a ferrule. Every fitting I have ever had to replace have been push-in type fittings. I will say the ones I had to replace have been plastic and the issue could be more about the fact the plastic has dried out and is getting brittle and less about being the push in types. I will admit my fittings kit that I keep in the truck is all the push in plastic types. They are quick and easy. They are also great for those hard to reach places that you can not see in to very easily or get a wrench in to. Link to comment Share on other sites More sharing options...
OldFlySwatter Posted December 7, 2015 Report Share Posted December 7, 2015 I also try to only use the brass DOT fittings with the plastic air lines. This way if it's leaking I can tighten it up. It is my understanding that the DOT fittings have the built in insert that goes inside the air line as you push it in. This insert is what the ferrule crushes down on to make the seal. The ones like you buy at Lowe's or Home Depot without the insert are made for copper lines or other metal lines. NAPA stores carry the DOT type. Hope this helps. Ed Link to comment Share on other sites More sharing options...
SuiteSuccess Posted December 7, 2015 Report Share Posted December 7, 2015 Agree with above Al. I try to use the ferruled brass where possible. What size 1/4", 3/8", 1/2"? Here is a site that sells them. Look for Parker or good name brand and as said above be sure they are for nylon airline NOT copper. http://brassfittings.midamericafittings.com/product/r-nylon-tubing-air-brake-fittings-for-nylon-tubing/air-brake-fittings-elbow Can also be found as said above at some NAPAs, Fastenal, Graingers. Link to comment Share on other sites More sharing options...
Scrap Posted December 7, 2015 Report Share Posted December 7, 2015 http://www.amazon.com/Legris-D-O-T-Push-Bulkhead-Union/dp/B007IV6EUY if you want an o-ring across both sides of the bulkhead part http://www.amazon.com/SMC-KV2E07-00-fitting-bulkhead-union/dp/B00DD7KZSO/ref=sr_1_2?ie=UTF8&qid=1449513676&sr=8-2&keywords=kv2e07+fitting if you want brass body and don't care about the o-ring https://peterbilttruckparts.com/hoses-belts-fittings/fitting-90-deg-elbow-stem-j24 stem 90 for each end of the bulkhead fitting Link to comment Share on other sites More sharing options...
alan0043 Posted December 8, 2015 Author Report Share Posted December 8, 2015 I also try to only use the brass DOT fittings with the plastic air lines. This way if it's leaking I can tighten it up. It is my understanding that the DOT fittings have the built in insert that goes inside the air line as you push it in. This insert is what the ferrule crushes down on to make the seal. The ones like you buy at Lowe's or Home Depot without the insert are made for copper lines or other metal lines. NAPA stores carry the DOT type. Hope this helps. Ed Hi Guys, I want to 'Thank' everyone for the help. I learned something about air line fittings. I did not know about the built in insert on the DOT fittings. It make sense for the plastic lines. I am glad that I asked a question or two about these fittings. Now I know what to look for. Parker has always been a good name in fittings. The nice thing about my area is that there are several stores that I can go into to find these fittings.. It sounds like I might need a bulkhead fitting to do what I want to do. Thanks again for the help, Al Al Link to comment Share on other sites More sharing options...
