gnikk Posted December 6, 2015 Report Share Posted December 6, 2015 I am considering switching over to AGM batteries so which would give me the most usable amps 4-6volt or 4-12volt??? I am looking at the 12 volt AGM batteries sold at Sam's club. They are manufactured by Johnson Controls. Energizer AGM Commercial Battery - Group Size 31C Thanks Ken Link to comment Share on other sites More sharing options...
Yarome Posted December 6, 2015 Report Share Posted December 6, 2015 I am considering switching over to AGM batteries so which would give me the most usable amps 4-6volt or 4-12volt??? I am looking at the 12 volt AGM batteries sold at Sam's club. They are manufactured by Johnson Controls. The 12v AGM's you're looking at are actually a hybrid deep cycle battery.. half starter battery/deep cycle. Any battery that shows CCA's would be the same. You would get more bang for your buck and available storage capacity with a "true" deep cycle battery. I would highly doubt that Sam's club carries a true deep cycle 12 or 6 volt AGM so the best you could do would be to go with the 12v 31's or shop at a specialty store or online. In this case, a deep cycle battery will give you nearly 2x the storage capacity in nearly the same amount of space. Ie., 12v AGM hybrids will typically have around a 100ah capacity. 2 - 6v AGM deep cycle AGM's would generally be more in the 220ah range. Is there a particular reason you are wanting to with AGM's? Sam's WOULD have true deep cycle 6v GC (golf cart) wet cell batteries that would run you around $150-$170 a pair for 220ah's. Link to comment Share on other sites More sharing options...
oldjohnt Posted December 6, 2015 Report Share Posted December 6, 2015 I will be at Sams in the next day or two, I will investigate what they are selling. That being said, I bought my 6 volt true deep cycle EG2 or EG Extended (I forget) flooded lead acid 230 Amp Hour batteries there a couple years ago and at that time my local store DID NOT HAVE THE SAME IN AGM. It would be my first "pure guess" until I go there, if they are selling a 12 volt AGM Id bet like Yarome they are sure, AGM, but they may be more like what I consider semi or quasi deep cycle RV/Marine batteries designed to start a huge outboard motor but still be decent for long term low amperage trolling motor operation. If you want more energy storage capacity and want to compare apples to apples YOU NEED TO KNOW THE AMP HOURS not the CCA etc which starting batteries are usually rated at. SOOOOOOOOO look at (if labeled which I doubt) the Amp Hours of those batteries and compare that to a true deep cycle golf cart (be it lead acid or AGM) battery. Its NOT if its an AGM or lead acid, its how many amp hours. Each have advantages and disadvantages and AGM or lead isnt the issue ITS HOW MANY AMP HOURS OF ENERGY STORAGE and the more the better for low current deep draw down like an RV uses. That's why you want a true deep cycle NOT an auto start battery or a semi hybrid REGARDLESS if AGM or not........ That's my story n Ima stickin to it..................... John T Link to comment Share on other sites More sharing options...
hemsteadc Posted December 6, 2015 Report Share Posted December 6, 2015 The ones with the most amp-hours. Link to comment Share on other sites More sharing options...
KRum Posted December 7, 2015 Report Share Posted December 7, 2015 Check out the VMaxx website they have a 10% discount, free shipping and maybe no sales tax!... http://www.vmaxtanks.com/V6-225-6Volts-225AH-Deep-Cycle-High-performance-AGM-Battery-_p_48.html Link to comment Share on other sites More sharing options...
Yarome Posted December 7, 2015 Report Share Posted December 7, 2015 Check out the VMaxx website they have a 10% discount, free shipping and maybe no sales tax!... Hm! That's doesn't look like a bad entry level AGM. $907.16 for 450ah's.. delivered.. Not too shabby! 900 cycles @50%. 1 year warranty. 10% off is first time purchase only and good through 12/31. Krum, you should post that link up under a new thread so other can take advantage of it. Link to comment Share on other sites More sharing options...
KRum Posted December 7, 2015 Report Share Posted December 7, 2015 Another thing to think about if you are in the market to buy or replace a battery bank is that you could also buy a small solar kit (say a 2-400w system)... The price of that and the battery bank would be eligible for a 35% Fedreal tax credit ;-) Link to comment Share on other sites More sharing options...
Jack Mayer Posted December 7, 2015 Report Share Posted December 7, 2015 If you can fit them, I like the L16 from Fullriver. But they do require a tall storage area. Link to comment Share on other sites More sharing options...
Pat & Pete Posted December 7, 2015 Report Share Posted December 7, 2015 Maybe : http://www.theinverterstore.com/12-volt-deep-cycle-batteries-200ah.html# Link to comment Share on other sites More sharing options...
Yarome Posted December 7, 2015 Report Share Posted December 7, 2015 Maybe : http://www.theinverterstore.com/12-volt-deep-cycle-batteries-200ah.html# I would still go with the others. Splitting the weight makes them more manageable, generally will have heavier plates in the 6v cells, you're getting 50ah's more and 900 cycles (vs. 500) @50% DOD for the same price. Link to comment Share on other sites More sharing options...
