SandeeAR Posted February 22, 2015 Report Share Posted February 22, 2015 Water will not flow into the RV. We have check water bib, hose is not frozen (just filled tank with the hose). Took apart fitting entering RV, no blockage. Pump is off. We are baffled. Any ideas? Of course it's Saturday night and RV repair closed until Monday. 25' Tioga Ranger. Btw it had frozen at the faucet 2 days earlier, so water flow for 2 days. All is thawed now and faucet repaired. Link to comment Share on other sites More sharing options...
Chad Heiser Posted February 22, 2015 Report Share Posted February 22, 2015 Do you have a water pressure regulator on the hose? If so, I have had one basically vapor lock on me and not let water pass through it. Remove that and see if it fixes your problem. Link to comment Share on other sites More sharing options...
bigjim Posted February 22, 2015 Report Share Posted February 22, 2015 I will say I have had an issue with a pressure reducers 2-3 times in my rving history. I chalked it up to the extremely high mineral content but don't really know. It doesn't make sense to me but it has happened . Link to comment Share on other sites More sharing options...
Rif Posted February 22, 2015 Report Share Posted February 22, 2015 Sandee, You say you took apart the fitting on the side of the RV and found no blockage. There is usually a check valve built into that fitting. It allows water to go in but not come out. It may be that the check valve is stuck or has otherwise failed somehow. Occasionally the check valve is located farther down the line, but that's kind of unusual. Link to comment Share on other sites More sharing options...
SandeeAR Posted February 22, 2015 Author Report Share Posted February 22, 2015 No water pressure regulator as we are at the kids house. We use one at the parks. Link to comment Share on other sites More sharing options...
SandeeAR Posted February 22, 2015 Author Report Share Posted February 22, 2015 Sandee, You say you took apart the fitting on the side of the RV and found no blockage. There is usually a check valve built into that fitting. It allows water to go in but not come out. It may be that the check valve is stuck or has otherwise failed somehow. Occasionally the check valve is located farther down the line, but that's kind of unusual. . My SIL took it apart. That is all we can figure is it has failed. He could push it with his finger and make it work. At the time I posted I didn't know it was called a check value. Link to comment Share on other sites More sharing options...
Rif Posted February 22, 2015 Report Share Posted February 22, 2015 If you have water in your tank and everything works when the pump is turned on, the check valve is likely the problem. You mentioned a frozen hose. Is there any chance your water line inside the RV near the fill valve has frozen? How cold is it where you are, and how well insulated is that area? On Edit: Normally the check valves fail by letting water leak back out. To have one fail by preventing water from flowing is is less common, but not unheard of. Link to comment Share on other sites More sharing options...
Kirk W Posted February 22, 2015 Report Share Posted February 22, 2015 My thoughts are much like Rif. Are we correct in assuming that you have observed water from the RV end of the hose with it disconnected from the RV and the hydrant turned on? If so that pretty well eliminates any problem outside of the RV. I really see no choice than the entry fitting as the problem unless there happens to be a screen on the hose washer that is plugged, but I'd have thought that would have been noticed when checking the hose connection. Like Rif, I have seen many of those check valves at the fresh water fitting fail by allowing water to leak back out when no hose is connected and the water pump is in use, but none that failed closed and blocked water entry from the hose. Even so, that is possible but before you call an RV tech there is one more thing that I would verify. Are you absolutely certain that there is not a frozen spot in the water supply line into your RV, between the fitting that you checked and the fresh water system? In most cases there is a foot or two of water line between the fitting and any insulated/heated areas and that line can freeze and block any water entry. I would apply some heat there with a blow-dryer on low setting to make sure that line is not frozen. Link to comment Share on other sites More sharing options...
Dennis M Posted February 22, 2015 Report Share Posted February 22, 2015 Yeah, I've seen that stinkin' little check valve fail and prevent water flow in. I've also had them leak out a half tank of fresh water overnight. I took the check valve out completely and replaced it with a simple hardware store shut-off valve. Has worked fine for years. Only drawback is I have to go out and turn off the valve if I want to switch from park water to the pump, no big deal. At the same time I put a pressure gauge and a quick disconnect outside of the valve so I can hook up easily and look at water pressure before I open the valve. Link to comment Share on other sites More sharing options...
SandeeAR Posted February 22, 2015 Author Report Share Posted February 22, 2015 Thanks for the help all. SIL took the check valve out last night and put it back. During the night he kept thinking it didn't look right when he took it out. He took it out again and the spring was in wrong. Fixed that and it works fine! Link to comment Share on other sites More sharing options...
Barbaraok Posted February 23, 2015 Report Share Posted February 23, 2015 Aren't SILs wonderful to have around. Barb Link to comment Share on other sites More sharing options...
Rif Posted February 23, 2015 Report Share Posted February 23, 2015 Yea! Thanks for letting us know. Link to comment Share on other sites More sharing options...
