rider10099 Posted February 19, 2015 Report Share Posted February 19, 2015 Went to get fuel. Fueled up, started up engine and pulled forward and reset the trip segment of the computer display. Shut down, went in to pay came back out started up and display is blank only the back light appears any ideas? Everything else seems normal. rider10099 Oregon 2001 Volvo 610 ved12 engine and autoshift 3612 Keystone Raptor https://picasaweb.google.com/johnrowton/HDT...922315348539106 Link to comment Share on other sites More sharing options...
rider10099 Posted February 19, 2015 Author Report Share Posted February 19, 2015 Anybody any ideas? rider10099 Oregon 2001 Volvo 610 ved12 engine and autoshift 3612 Keystone Raptor https://picasaweb.google.com/johnrowton/HDT...922315348539106 Link to comment Share on other sites More sharing options...
hone eagle Posted February 19, 2015 Report Share Posted February 19, 2015 scratching my head here. is the night lighting mode on? 2005 volvo 670 freedomline singledNewmar Torrey Pine 34rskswoot woot Link to comment Share on other sites More sharing options...
rider10099 Posted February 19, 2015 Author Report Share Posted February 19, 2015 mystery remains but problem gone. Went out turned on the key and display came on ...... puzzled as to what caused it gremlins perhaps. rider10099 Oregon 2001 Volvo 610 ved12 engine and autoshift 3612 Keystone Raptor https://picasaweb.google.com/johnrowton/HDT...922315348539106 Link to comment Share on other sites More sharing options...
tyates007 Posted February 20, 2015 Report Share Posted February 20, 2015 My 99 did the same thing and then one day went out and did not come back on if you are referring to the odometer in the center of the panel. Had Volvo check it and turned out to be an issue with the cluster that could not be repaired. Link to comment Share on other sites More sharing options...
rdickinson Posted February 20, 2015 Report Share Posted February 20, 2015 This happened to me a couple of years ago. It was something to do with dimming the screen, can't remember specifically. I was able to see the screen very faintly in certain light conditions and was able to switch it back. Best I can do. I sent an e-mail to a guy in Edmonton who fixes Volvo Dash clusters, hopefully he gets back to me. The gent in Edmonton figures it could be a bad solder joint especially if it is intermittent. Link to comment Share on other sites More sharing options...
SunJuniper Posted February 20, 2015 Report Share Posted February 20, 2015 could be the ole bad solder joints on the circuit boards in the cluster. if you REALLY handy with a soldering iron (not gun) , there is a guide around here and maybe on the heavy haulers resource website on how to fix it. ive fixed mine and problem solved. about 4 hours to go over mine with a magnifying glass and resolder all the cracked solder joints. there was quite a few. Fulltimer Class of 2007 1998 Volvo VNL64T610 Detroit Series 60 12.7 470HP/1650TQ Eaton 18spd 228"WB Tandem2006 40' ToyHauler 3 slides and a 14' Toybox Link to comment Share on other sites More sharing options...
Alie&Jim's Carrilite Posted February 20, 2015 Report Share Posted February 20, 2015 On a '98 610 there is a screen in at the bottom of the left-hand cluster, is this the screen your referring to? If so, could I have the guys name from Edmonton, because mine is dead as well. But will the truck operate with it unplugged / removed? Alie & Jim + 8 paws 2017 DRV Memphis BART- 1998 Volvo 610 Lil'ole 6cyl Cummins Link to comment Share on other sites More sharing options...
rdickinson Posted February 20, 2015 Report Share Posted February 20, 2015 If its the guy on Kijiji, he is not familiar with that model Link to comment Share on other sites More sharing options...
hdonlybob Posted February 22, 2015 Report Share Posted February 22, 2015 My 2001 610 did that for several years when it was cold (as in 0 degrees or so) on start up.. after warming up, shut off and restart and it was fine.. I suspect eventually quit.. Cheers, Bob 1989 Safari Serengeti 34'Towing a 1952 M38A1 Military Willys Past HDT owner Link to comment Share on other sites More sharing options...
