OU812 Posted October 10, 2019 Report Share Posted October 10, 2019 I have a 98 Volvo N 14 , 10 speed. 670,00 miles, When attempting to start, with the key. ( I let the lights come on and don't crank until the seat belt light goes off) No dash lights I get nothing, then back off, second try I get dash lights, ( voltage is 12.8 volts) a click and ECM, and dash lights go out. Back off, third or forth try starter engages and engine start up as usual. Battery's are 6 mouths old ( charging at !3.8 when running) and clean. I have replaced the starter relay, and the electrical connection at the bottom of key switch. The electrical system is all original, only add on is a trailer brake controller. No orders (smell of something hot), checked for loose connections, all over. Truck runs fine, and intersegments are normal when running. Has any one had a simmer experience whit their truck? No I'm not next to a repair shop...but I know that I could get to one,.. in a few 100 miles. (Volvo). I' thinking of a starter going bad...?? Is there something I should be looking at ?? I think I have covered everything that I attempted and the systems. Any in put is appreciated Thank you OU812 Quote Link to comment Share on other sites More sharing options...
DesertMiner Posted October 10, 2019 Report Share Posted October 10, 2019 Starter solenoid? Check all of your grounds and the fuses at the battery compartment area. Quote Link to comment Share on other sites More sharing options...
Darryl&Rita Posted October 10, 2019 Report Share Posted October 10, 2019 Switch. Quote I have been wrong before, I'll probably be wrong again. 2000 Kenworth T 2000 w/N-14 and 10 speed Gen1 Autoshift, deck built by Star Fabrication 2006 smart fourtwo cdi cabriolet 2007 32.5' Fleetwood QuantumPlease e-mail us here. Link to comment Share on other sites More sharing options...
OU812 Posted October 10, 2019 Author Report Share Posted October 10, 2019 Problem solved........ long story short...... Replaced a low resistance fusible link. (corroded inside) Now the key worked all the time. Thank you for all your replies. OU812 Quote Link to comment Share on other sites More sharing options...
castlewood57 Posted November 7, 2019 Report Share Posted November 7, 2019 On 10/10/2019 at 2:13 PM, OU812 said: Where was this fusible link at? Down by the battery? I have a 2007 Volvo 670 and I can turn key and display goes blank, but no sounds of it trying to turn over... Or do I have a ton of dead batteries instead? Problem solved........ long story short...... Replaced a low resistance fusible link. (corroded inside) Now the key worked all the time. Thank you for all your replies. OU812 Quote Link to comment Share on other sites More sharing options...
