GlennWest Posted April 28, 2019 Report Share Posted April 28, 2019 Well, our rooftop domestic fan failed again so decided not to spend anymore money on it. Well my little 5/10 job turned into 6/12 and I haven't had any projects time. So we were forced to use just the one 12k, 110v Pioneer mini split. Much to our surprise it has kept us very cool even up to 90 degrees so far. We are using the living room ceiling fan to help even out temps inside. A small upright Dyson fan pulling air into bedroom. Even at 90 degrees we can easily get it down to 70 inside. And you will have a shaw on too. Lol. I know this not July and August Texas heat yet but this is impressive. Quote 2003 Teton Grand Freedom towed with 2006 Freightliner Century 120 across the beautiful USA welding pipe.https://photos.app.goo.gl/O32ZjgzSzgK7LAyt1 Link to comment Share on other sites More sharing options...
Daveh Posted April 28, 2019 Report Share Posted April 28, 2019 Thanks for the update. Quote Dave and Lana Hasper Link to comment Share on other sites More sharing options...
Smitty77_7 Posted April 28, 2019 Report Share Posted April 28, 2019 Cool (Sorry, it just seemed like the right word to use:)!) that it's working so well... Best to you and all, Smitt Quote Be safe, have fun, Smitty 04 CC Allure "RooII" - Our "E" ride for life! Link to comment Share on other sites More sharing options...
GlennWest Posted April 28, 2019 Author Report Share Posted April 28, 2019 It has we waiting to see if I will still need the upgrade. Quote 2003 Teton Grand Freedom towed with 2006 Freightliner Century 120 across the beautiful USA welding pipe.https://photos.app.goo.gl/O32ZjgzSzgK7LAyt1 Link to comment Share on other sites More sharing options...
TLRam1 Posted April 29, 2019 Report Share Posted April 29, 2019 Thanks for the update, waiting to see how it does when it gets hotter. Quote Terry Link to comment Share on other sites More sharing options...
GlennWest Posted April 29, 2019 Author Report Share Posted April 29, 2019 Yes. Quote 2003 Teton Grand Freedom towed with 2006 Freightliner Century 120 across the beautiful USA welding pipe.https://photos.app.goo.gl/O32ZjgzSzgK7LAyt1 Link to comment Share on other sites More sharing options...
Jack Mayer Posted April 29, 2019 Report Share Posted April 29, 2019 Glenn, Good update. Question - some of the people that have LG mini-splits in their RVs are complaining about the humidity. It is simply not properly dehumidifying. Some are saying this is "normal". WHich IMO it is not. My Mitsubishi properly dehumidifies. And I assume your Pioneer does. Can you confirm that, and comment on any other "funny things" you have seen in use? Quote Jack & Danielle Mayer #60376 Lifetime Member Living on the road since 2000PLEASE no PM's. Email me. jackdanmayer AT gmail 2016 DRV Houston 44' 5er (we still have it) 2022 New Horizons 43' 5er 2016 Itasca 27N 28' motorhome 2019 Volvo 860, D13 455/1850, 236" wb, I-Shift, battery-based APU No truck at the moment - we use one of our demo units 2016 smart Passion, piggyback on the truck -------------------------------------------------------------------------See our website for info on New Horizons 5th wheels, HDTs as tow vehicles, communications on the road, and use of solar powerwww.jackdanmayer.com Principal in RVH Lifestyles. RVH-Lifestyles.com Link to comment Share on other sites More sharing options...
GlennWest Posted April 29, 2019 Author Report Share Posted April 29, 2019 (edited) Mine pulls enough out that is is very pleasant in here. Know it really puts a steady stream of water out the drain. Neighbor thought I had a water leak. So it definitely working. Also it is comfortable now at 74 where the Domenic's we had to get to 70 to be comfortable. Edited April 29, 2019 by GlennWest Quote 2003 Teton Grand Freedom towed with 2006 Freightliner Century 120 across the beautiful USA welding pipe.https://photos.app.goo.gl/O32ZjgzSzgK7LAyt1 Link to comment Share on other sites More sharing options...
GlennWest Posted April 29, 2019 Author Report Share Posted April 29, 2019 That would happen with the typical AC if it was oversized. Wonder if same applies to the the mini splits. They are variable out put and they may not run enough to pull humidity down. Quote 2003 Teton Grand Freedom towed with 2006 Freightliner Century 120 across the beautiful USA welding pipe.https://photos.app.goo.gl/O32ZjgzSzgK7LAyt1 Link to comment Share on other sites More sharing options...
lockmup68 Posted May 2, 2019 Report Share Posted May 2, 2019 I’m trying to figure out if the mini split cassette can go in the ceiling and use the existing ducting. Quote 2003 International Eagle 9200i, Cummins ISX, Freedomline 2007 Teton Scottsdale XT4 Link to comment Share on other sites More sharing options...
GlennWest Posted May 2, 2019 Author Report Share Posted May 2, 2019 They do make a unit to go in the ducts of a house but won't fit our ducts. You don't really want to do this. Our roof area gets hot. It would lower the efficiency of the mini split. Our Dyson fan does a good job to circulate air to bedroom. Now Space Craft runs an interior duct. Maybe you should look at one of them. Wouldn't be hard to do Quote 2003 Teton Grand Freedom towed with 2006 Freightliner Century 120 across the beautiful USA welding pipe.https://photos.app.goo.gl/O32ZjgzSzgK7LAyt1 Link to comment Share on other sites More sharing options...
GlennWest Posted May 2, 2019 Author Report Share Posted May 2, 2019 Only issue we had had with ours is drain clogged up. Assume alge clogged it. It drains inside then. Bummer. But a quick suction with small shop vac fixed that. Filter needs cleaning fairly often. Dirty filter really hurts output. Simple job, just need to remember to do it Quote 2003 Teton Grand Freedom towed with 2006 Freightliner Century 120 across the beautiful USA welding pipe.https://photos.app.goo.gl/O32ZjgzSzgK7LAyt1 Link to comment Share on other sites More sharing options...
