Normal Temp Range
ewacowboy
2007 Freightliner M2-106 with Mercedes and Allison 6-speed. Just started our long range adventure and have noticed the engine temps run around 180 and the transmission around 165 cruising at 1650 RPM. When pulling a grade both temps run higher - which I would expect. While running steep grades the engine runs up to about 195 before the engine fan kicks on and the transmission can run as high as 200 - 205.....are these normal operating ranges? We're usually running the AC at the time.
Jim
Jim and Kellie
2017 DRV 38RSSA Mobile Suite
2016 Western Star 5700xe
YouTube Channel
As long as I kept the transmission locked in a low enough gear that it wasn't shifting often I saw a bit less temp rise there than you are seeing, otherwise about the same.
Cowboy - Just a question - could this be the first time you had real gauges? I know that my Ford truck the gages were just fancy idiot lights. I put real ones in and they read in the same temps as yours. The HDT temps run in the same range.
Common temps for running engines.
Hahaha....yes, that's why I'm asking. I've never seen a tranny run over 200 so I thought I'd ask.
Thanks for the support guys!
Jim and Kellie
YouTube Channel
My F-250 transmission had no problem getting to 300+ degrees if the torque converter unlocked on a full throttle hill climb and I didn't downshift fast.
  • 1 month later...
