Cheyenne1 Posted May 13 Report Share Posted May 13 I just finished up my truck today and took on a short trip to shake it down. Only issue is the ABS light came on. Truck was fine before. stopped and disconnected the data link plug, re started, light went off and stayed off. Has anyone had issues like this ? I have not looked at anything or scanned codes to see what code it was. truck is a 2019 Peterbilt 579. Looking for am easy solution as this project has taken way to long. Lol thanks Quote Link to comment Share on other sites More sharing options...
Moresmoke Posted May 13 Report Share Posted May 13 Could be as simple as a loose connection, or more involved. Really need codes to tell what is up. Unless you have software to connect to the brake module, you may not show any codes when the ABS light is not on. Quote Link to comment Share on other sites More sharing options...
mike5511 Posted May 13 Report Share Posted May 13 12 hours ago, Cheyenne1 said: I just finished up my truck today and took on a short trip to shake it down. Only issue is the ABS light came on. Truck was fine before. stopped and disconnected the data link plug, re started, light went off and stayed off. Has anyone had issues like this ? I have not looked at anything or scanned codes to see what code it was. truck is a 2019 Peterbilt 579. Looking for am easy solution as this project has taken way to long. Lol thanks I’d call DirecLinc. After I made sure my wiring was all correct. Quote Link to comment Share on other sites More sharing options...
Cheyenne1 Posted May 16 Author Report Share Posted May 16 Wiring was all correct. for some reason the truck did not like the module at first. After I set it up the 3rd time the trucks abs module was ok with it. Talked to Allen at direct link, he had never seen this happen before. All is good now with it. Quote Link to comment Share on other sites More sharing options...
