GlennWest Posted March 6, 2023 Report Share Posted March 6, 2023 Some time back I replaced motor and spring in our awning. Ever since controls have been reversed. It would go out good but come in by stopping and having to restart it. Simply release switch and enguage again and it go. Have to do this several times to get in. Yesterday I reversed wires to get direction corrected. Now it comes in good but going out is problem. So has nothing to do with spring tension. Does this with remote and wall switch. It works but is a misterery to me. Quote 2003 Teton Grand Freedom towed with 2006 Freightliner Century 120 across the beautiful USA welding pipe.https://photos.app.goo.gl/O32ZjgzSzgK7LAyt1 Link to comment Share on other sites More sharing options...
Will B. Posted March 6, 2023 Report Share Posted March 6, 2023 Sounds almost like a voltage issue. Quote 2018 Grand Design Momentum 399TH • 2019 Ford F-350 (DRW) 2016 Harley-Davidson Heritage • 2013 Harley Sportster with a sidecar Web: https://MyRVRadio.com • Facebook: https://fb.com/MyRVRadio Link to comment Share on other sites More sharing options...
Kirk W Posted March 6, 2023 Report Share Posted March 6, 2023 Since the problem moved with the reversing of the connections, it must not be a mechanical or a motor problem. I would start by monitoring the voltage to the motor in each direction to see if they are different. If so, work backward to see where the voltage drop is taking place. Quote Good travelin !...............KirkFull-time 11+ years...... Now seasonal travelers.Kirk & Pam's Great RV Adventure Link to comment Share on other sites More sharing options...
Anawilliam850 Posted March 6, 2023 Report Share Posted March 6, 2023 It sounds like there may be a wiring issue with your awning motor. Reversing the wires to change the direction of the motor may have caused a problem with the wiring or the connections. This could be causing the intermittent behavior that you're experiencing when using the awning controls. I would recommend checking all the wiring connections to make sure they are secure and properly connected. You may want to consult the manufacturer's instructions for the motor or seek the help of a professional electrician or repair person to diagnose and fix the issue. It's also possible that the problem is with the control switches or the remote. You could try replacing these components to see if that resolves the issue. In any case, it's important to address the issue as soon as possible, as an improperly functioning awning could be a safety hazard. Quote Link to comment Share on other sites More sharing options...
GlennWest Posted March 6, 2023 Author Report Share Posted March 6, 2023 How can that be a safety issue? Quote 2003 Teton Grand Freedom towed with 2006 Freightliner Century 120 across the beautiful USA welding pipe.https://photos.app.goo.gl/O32ZjgzSzgK7LAyt1 Link to comment Share on other sites More sharing options...
Chalkie Posted March 6, 2023 Report Share Posted March 6, 2023 17 minutes ago, GlennWest said: How can that be a safety issue? The most obvious in my mind would be the possibility of the awning coming open unexpectedly, saying going down the road or on a very windy day. Quote Link to comment Share on other sites More sharing options...
Kirk W Posted March 7, 2023 Report Share Posted March 7, 2023 26 minutes ago, GlennWest said: How can that be a safety issue? Other than opening when traveling, I can't think of any way it would be an electrical safety problem. Since the motor is DC, reversing to polarity is the way that the motor changes directions so there should be no problem with that at all. That is exactly what the switch does for in or out, unless you have some unique design that I have never seen. To quote the Precision Motors website: "Simply put, DC motors can turn in either direction (clockwise or counter-clockwise) and can be easily controlled by inverting the polarity of the applied .." As I said previously, I do think that it might point you in the right direction to monitor the voltage each direction to see if it might be low in the problem direction. Quote Good travelin !...............KirkFull-time 11+ years...... Now seasonal travelers.Kirk & Pam's Great RV Adventure Link to comment Share on other sites More sharing options...
GlennWest Posted March 7, 2023 Author Report Share Posted March 7, 2023 (edited) 1 hour ago, Chalkie said: The most obvious in my mind would be the possibility of the awning coming open unexpectedly, saying going down the road or on a very windy day. No idea how that could happen. It works in it goes in and out and stays where it is put. Just stopping every foot or so of travel in one direction only. Worked perfectly before the motor gear stripped out and I put new one in. I couldn't understand either why controls were reversed. Can't plug it in wrong. I reversed wiring coming out of controller. I will put a monitor on it tomorrow. I have a 12v drill battery. Going to disconnect wiring tomorrow and bypass controller. See what happens. Edited March 7, 2023 by GlennWest Quote 2003 Teton Grand Freedom towed with 2006 Freightliner Century 120 across the beautiful USA welding pipe.https://photos.app.goo.gl/O32ZjgzSzgK7LAyt1 Link to comment Share on other sites More sharing options...
Chalkie Posted March 7, 2023 Report Share Posted March 7, 2023 13 hours ago, GlennWest said: No idea how that could happen. I have no particular idea either but to overlook the possibility seems to me to be a direct challenge to Murphy. 😂 Quote Link to comment Share on other sites More sharing options...
