Bkseyer Posted February 17, 2023 Report Share Posted February 17, 2023 Hello, I have the Service Ranger software and Changed the starting gear to 3rd and Max at 5 downloaded it fine. But at startup it still shows the starting gear in 2nd. Any info would be great! Quote Link to comment Share on other sites More sharing options...
jeffw Posted February 17, 2023 Report Share Posted February 17, 2023 I've got the same transmission and was told the only choice was 1st or 2nd.... Quote 2007 Volvo 780 Volvo D12D, 465hp, 1650 ft/lbs tq., ultrashift Link to comment Share on other sites More sharing options...
ddm502001 Posted February 17, 2023 Report Share Posted February 17, 2023 SO Glad have only a Standard Stick, Start in any gear I want to!!!🤪 Dave Quote Link to comment Share on other sites More sharing options...
jeffw Posted February 18, 2023 Report Share Posted February 18, 2023 10 hours ago, Bkseyer said: Hello, I have the Service Ranger software and Changed the starting gear to 3rd and Max at 5 downloaded it fine. But at startup it still shows the starting gear in 2nd. Any info would be great! The only other trick I can help with is when bobtailing, if you want to skip-shift, you can go to manual and press the 'up' button twice. The requirement is that you have to be at high enough RPM that the 2nd shift will land high enough RPM-wise. I think that means shifting at 1600RPM or a bit over. Quote 2007 Volvo 780 Volvo D12D, 465hp, 1650 ft/lbs tq., ultrashift Link to comment Share on other sites More sharing options...
SuiteSuccess Posted February 18, 2023 Report Share Posted February 18, 2023 19 hours ago, jeffw said: I've got the same transmission and was told the only choice was 1st or 2nd.... Same here. Had mine reset at dealer and they couldn’t change above 2nd. Quote 2006 Volvo 780 "Hoss" Volvo D12, 465hp, 1650 ft/lbs tq., ultrashift Bed Build by "JW Morgan's Custom Welding" 2017 DRV 39DBRS3 2013 Smart Passion Coupe "Itty Bitty" "Don't go around saying the world owes you a living. The world owes you nothing. It was here first!" Link to comment Share on other sites More sharing options...
