GlennWest Posted November 23, 2022 Report Share Posted November 23, 2022 Do I need this for the solar? 250vdc at 10 amps. Or just unplug one end at panels and make connection at breakers? Quote 2003 Teton Grand Freedom towed with 2006 Freightliner Century 120 across the beautiful USA welding pipe.https://photos.app.goo.gl/O32ZjgzSzgK7LAyt1 Link to comment Share on other sites More sharing options...
D&J Posted November 23, 2022 Report Share Posted November 23, 2022 Just cover the panels, no sun no juice. Denny Quote Denny & Jami SKP#90175 Most Timing with Mac our Scottie, RIP Jasper our Westie 2013 F350 SC DRW 6.2 V8 4.30 Gears 2003 HH Premier 35FKTG Home Base Nebraska Link to comment Share on other sites More sharing options...
GlennWest Posted November 23, 2022 Author Report Share Posted November 23, 2022 (edited) That is a lot of cover. The entire roof. I have done ac with no gloves just be careful not to touch ground. Be easy to do that with the pv wire. All 4 ends are tapped so I should be safe. Edited November 23, 2022 by GlennWest Quote 2003 Teton Grand Freedom towed with 2006 Freightliner Century 120 across the beautiful USA welding pipe.https://photos.app.goo.gl/O32ZjgzSzgK7LAyt1 Link to comment Share on other sites More sharing options...
Randyretired Posted November 23, 2022 Report Share Posted November 23, 2022 Whenever I do solar I leave the panels unplugged until all of the wiring is done. That voltage, especially DC 😱. Don't take chances and be very careful. My choice is to wire everything and then plug the panels in after dark. Then switch things on one at a time. Quote Randy 2001 Volvo VNL 42 Cummins ISX Autoshift Link to comment Share on other sites More sharing options...
GlennWest Posted November 23, 2022 Author Report Share Posted November 23, 2022 Sounds like a good plan. Thanks Quote 2003 Teton Grand Freedom towed with 2006 Freightliner Century 120 across the beautiful USA welding pipe.https://photos.app.goo.gl/O32ZjgzSzgK7LAyt1 Link to comment Share on other sites More sharing options...
sandsys Posted November 23, 2022 Report Share Posted November 23, 2022 1 hour ago, Randyretired said: Whenever I do solar I leave the panels unplugged until all of the wiring is done. That voltage, especially DC 😱. Don't take chances and be very careful. My choice is to wire everything and then plug the panels in after dark. Then switch things on one at a time. Don't be parked under a Walmart parking lot light when doing this. My panels were charging at night at one. I still have trouble believing that happened. Linda Quote Blog: http://sandcastle.sandsys.org/ Former Rigs: Liesure Travel van, Winnebago View 24H, Winnebago Journey 34Y, Sportsmobile Sprinter conversion van Link to comment Share on other sites More sharing options...
GlennWest Posted November 23, 2022 Author Report Share Posted November 23, 2022 I hooked up the pv wires this evening. No sun and cloudy. No problem. Got battery disconnects mounted and wired. Hot line to one inverter. Supposed to rain again tomorrow Quote 2003 Teton Grand Freedom towed with 2006 Freightliner Century 120 across the beautiful USA welding pipe.https://photos.app.goo.gl/O32ZjgzSzgK7LAyt1 Link to comment Share on other sites More sharing options...
