XMAN Posted September 12, 2022 Report Share Posted September 12, 2022 HELP! Anyone know of a shop that aligns TT wheels. Hopefully in the south or southwest. After an axle broke off and was repaired my tires (double axle trailer) wear out on the inside very fast. Quote Link to comment Share on other sites More sharing options...
Star Dreamer Posted September 12, 2022 Report Share Posted September 12, 2022 I have a list that Morryde suggested for alignments and they show a few in AZ, TX, FL a couple in NM, and in other Southern States. Where will you be near and I can let you know which ones it shows. Quote 2005 Freightliner Century S/T, Singled, Air ride ET Jr. hitch 2019 46'+ Dune Sport Man Cave custom 5th wheel toy hauler Owner of the 1978 Custom Van "Star Dreamer" which might be seen at a local car show near you! Check out http://www.hhrvresource.com/ for much more info on HDT's. Link to comment Share on other sites More sharing options...
LindaH Posted September 12, 2022 Report Share Posted September 12, 2022 You might want to change the title of your post to something that describes what your post is about rather than using your user name. Quote LindaH 2014 Winnebago Aspect 27K 2011 Kia Soul Link to comment Share on other sites More sharing options...
Ray,IN Posted September 12, 2022 Report Share Posted September 12, 2022 9 hours ago, XMAN said: HELP! Anyone know of a shop that aligns TT wheels. Hopefully in the south or southwest. After an axle broke off and was repaired my tires (double axle trailer) wear out on the inside very fast. Wear on inside of tread only indicates incorrect camber. Are you sure the new axles are not installed upside-down? Trailer axles have a crown in them from the factory. As load is increased the crown flattens somewhat. reference: https://blog.easternmarine.com/trailer-axle-camber-what-its-all-about/ Quote 2000 Winnebago Ultimate Freedom USQ40JD, ISC 8.3 Cummins 350, Spartan MM Chassis. USA IN 1SG retired;Good Sam Life member,FMCA ." And so, my fellow Americans: ask not what your country can do for you--ask what you can do for your country. John F. Kennedy 20 Jan 1961 Link to comment Share on other sites More sharing options...
Ray,IN Posted September 12, 2022 Report Share Posted September 12, 2022 Just now, Ray,IN said: Wear on inside of tread only indicates incorrect camber. Are you sure the new axles are not installed upside-down? Trailer axles have a crown in them from the factory. reference: https://blog.easternmarine.com/trailer-axle-camber-what-its-all-about/ Quote 2000 Winnebago Ultimate Freedom USQ40JD, ISC 8.3 Cummins 350, Spartan MM Chassis. USA IN 1SG retired;Good Sam Life member,FMCA ." And so, my fellow Americans: ask not what your country can do for you--ask what you can do for your country. John F. Kennedy 20 Jan 1961 Link to comment Share on other sites More sharing options...
VC 23RSS Posted September 13, 2022 Report Share Posted September 13, 2022 Can you even align axles? A single wheel torsion axle probably but my Dexter Tandems sure don't appear to have any way to adust caster or toe. I think @Ray,IN knows what happened. Quote Link to comment Share on other sites More sharing options...
XMAN Posted September 13, 2022 Author Report Share Posted September 13, 2022 Star Dreamer, thanks but I see you drive one of those SUPER rigs, mine's just a 24ft travel trailer. I found a couple of shops that do semis but 14in. wheels are just too small for them. Still, I'm in Florida and if you have info on such I'd very much appreciate it. I believe part of the problem is axle alignment, the 2 are not exactly parallel to each other and maybe not even perpendicular to the frame. Quote Link to comment Share on other sites More sharing options...
Kirk W Posted September 13, 2022 Report Share Posted September 13, 2022 The service people at an RV dealership might be able to help you find a place to do it. Quote Good travelin !...............KirkFull-time 11+ years...... Now seasonal travelers.Kirk & Pam's Great RV Adventure Link to comment Share on other sites More sharing options...
XMAN Posted September 13, 2022 Author Report Share Posted September 13, 2022 No Ray, the new axle was installed right, BUT, I believe the new hanger may be off from where it's supposed to be. Linda thanks, I'm new at this although I've been a member for years. Quote Link to comment Share on other sites More sharing options...
Star Dreamer Posted September 13, 2022 Report Share Posted September 13, 2022 9 hours ago, XMAN said: Star Dreamer, thanks but I see you drive one of those SUPER rigs, mine's just a 24ft travel trailer. I found a couple of shops that do semis but 14in. wheels are just too small for them. Still, I'm in Florida and if you have info on such I'd very much appreciate it. I believe part of the problem is axle alignment, the 2 are not exactly parallel to each other and maybe not even perpendicular to the frame. Big or small doesn't hurt to try. In FL this is the list that they had: Horton Truck Service in Jacksonville Power Brake and Suspension in FT Lauderdale Tampa Spring Co in Ocala and in Tampa Josam in Orlando. I would probably lean towards the Tampa Spring Company places. Quote 2005 Freightliner Century S/T, Singled, Air ride ET Jr. hitch 2019 46'+ Dune Sport Man Cave custom 5th wheel toy hauler Owner of the 1978 Custom Van "Star Dreamer" which might be seen at a local car show near you! Check out http://www.hhrvresource.com/ for much more info on HDT's. Link to comment Share on other sites More sharing options...
