Dash AC Issues.
billyed
HELP! - My 40 foot diesel pusher dash AC is discharged again. I had it charged in June because it was discharged then as it was about 8 months previous to that. I have had a local RV dealer look at the system as well as an automotive AC soecialist shop and neith can find a leak in the system but it just will not retain a charge for even a full year. Any ideas?
Time to get some dye into the system. Get a better AC repair shop. They'll add dye, run the system, then use a UV lamp to narrow down the leaks.
Did those shops test both refrigerant lines from the compressor and back? That's over 80' of flexible lines.
The AC shop installed dye and tested all fittings at either end but nothing in the center as the lines are hidden within the underfloor covering but I am working on the assumption that as they appear to be hard lines with flexible ends, there should not be any leaks in the center sections.  To get at the center section of the lines is going to be major disassembly.
It has been suggested that this might be an internal leak within the compressor but I would have thought that would still show up on the dye leak test.
Any other ideas?
Those long lines are some what flexible but yes, hard on the outside. To leak-test them requires disconnecting both ends and pulling a vacuum, then allowing to sit undisturbed for a day, or until the vacuum lessens, whichever is less.
  • 6 months later...
Hmm, I wonder if a shop could disconnect both ends of the lines, cap one end of each and pressurize both lines. Let it sit for a day and then read the pressure to prove or disprove a line is leaking. Seems that might narrow your quest down...
If you found a line was leaking you could simply abandon that line and run a new one rather than dig for access to the culprit (maybe abandon both lines is one was proved to be leaking).
Edited by Domo
2008 36 QSH
2017 Jeep Cherokee TrailHawk
BlueOx towbar and baseplates
Roadmaster Brakemaster
Remember, there is a real person on the other side of your screen...
