durangodon Posted April 17, 2020 Report Share Posted April 17, 2020 (edited) I'm wanting to combine several pdf documents into a single document. I know Acrobat will do it. Is there a free program which will do that? Edited April 17, 2020 by durangodon Quote Link to comment Share on other sites More sharing options...
RayJay Posted April 17, 2020 Report Share Posted April 17, 2020 I've used PDF995 in the past. It has a lot of capabilities. Quote -- Ray & Wendy Full time wanna be - finally! 2014 Entegra Anthem 42RBQ 2018 Jeep Wrangler JLU Link to comment Share on other sites More sharing options...
Dutch_12078 Posted April 17, 2020 Report Share Posted April 17, 2020 I've used the online service at https://smallpdf.com/merge-pdf a few times, although I wouldn't recommend it for sensitive documents. For more secure offline use, I've had good results with https://www.starzsoft.com/pdf-converter/. Quote Dutch 2001 GBM Landau 34' Class A F-53 Chassis, Triton V10, TST TPMS 2011 Toyota RAV4 4WD/Remco pump ReadyBrute Elite tow bar/brake system Link to comment Share on other sites More sharing options...
durangodon Posted April 17, 2020 Author Report Share Posted April 17, 2020 1 hour ago, RayJay said: I've used PDF995 in the past. It has a lot of capabilities. Thanks. I downloaded the programs and it worked like a charm. Quote Link to comment Share on other sites More sharing options...
durangodon Posted April 17, 2020 Author Report Share Posted April 17, 2020 1 hour ago, Dutch_12078 said: I've used the online service at https://smallpdf.com/merge-pdf a few times, although I wouldn't recommend it for sensitive documents. For more secure offline use, I've had good results with https://www.starzsoft.com/pdf-converter/. Thanks. I will also download this one and try it. Quote Link to comment Share on other sites More sharing options...
durangodon Posted April 17, 2020 Author Report Share Posted April 17, 2020 2 hours ago, Dutch_12078 said: I've had good results with https://www.starzsoft.com/pdf-converter/. This one was even easier to do what I wanted. Thanks to both of you. Quote Link to comment Share on other sites More sharing options...
Dutch_12078 Posted April 17, 2020 Report Share Posted April 17, 2020 Glad it worked well for you , Don... Quote Dutch 2001 GBM Landau 34' Class A F-53 Chassis, Triton V10, TST TPMS 2011 Toyota RAV4 4WD/Remco pump ReadyBrute Elite tow bar/brake system Link to comment Share on other sites More sharing options...
lenp Posted April 18, 2020 Report Share Posted April 18, 2020 Another I have used for years is "Icecream PDF Split & Merge". Easy to use. Lenp Quote USN Retired 2002 Winnebago Ultimate Freedom 2012 F150 4x4 2018 Lincoln MKX 2019 HD Ultra Limited Link to comment Share on other sites More sharing options...
da'gheens Posted April 23, 2020 Report Share Posted April 23, 2020 Do you know if any of these pdf programs will separate a multi page pdf into separate files of each page and save them with a different name? I know you can do a virtual "print to pdf" print one page at a time and save it as a separate file. It just takes hours to do that with an 85 page document. Would be nice to find one that does it automatically. Thanks Quote Link to comment Share on other sites More sharing options...
lenp Posted April 24, 2020 Report Share Posted April 24, 2020 I think "PDF Split & Merge" will do that. Lenp Quote USN Retired 2002 Winnebago Ultimate Freedom 2012 F150 4x4 2018 Lincoln MKX 2019 HD Ultra Limited Link to comment Share on other sites More sharing options...
