dblr Posted April 20, 2019 Report Share Posted April 20, 2019 Henry are the springs that hold the head from flopping around anything special? Also the pin that goes thru to hold the spring in place can you get them anywhere or is that something special to the hitch? I had the front spring break and the right rear pin came out and is missing in action, the head flops around hitting the dog bones. Thanks for any info. 2017 River Stone Legacy 38MB 2001 T2000 Kenworth 2009 Smart Passion ET Junior hitch Link to comment Share on other sites More sharing options...
jeffw Posted April 21, 2019 Report Share Posted April 21, 2019 I have a spring in a bag at the truck (with the part # on the bag). Not sure when I'll get over to it, but I'll grab the part # next time I'm there. 2007 Volvo 780 Volvo D12D, 465hp, 1650 ft/lbs tq., ultrashift Link to comment Share on other sites More sharing options...
jenandjon Posted April 21, 2019 Report Share Posted April 21, 2019 Follow this link and call the tech support number. I have called a couple times. He is very helpful. https://ethitch.com/ Farmer, Trucker, Equipment operator, Mechanic Quando omni flunkus moritati-When all else fails, play dead I'm a man, but I can change, if I have to, I guess. Link to comment Share on other sites More sharing options...
dblr Posted April 21, 2019 Author Report Share Posted April 21, 2019 46 minutes ago, jeffw said: I have a spring in a bag at the truck (with the part # on the bag). Not sure when I'll get over to it, but I'll grab the part # next time I'm there. Thank you 41 minutes ago, jenandjon said: Follow this link and call the tech support number. I have called a couple times. He is very helpful. https://ethitch.com/ I ended up sending Henry a email, DUH why I didn't think of that at first?????? I guess a brain fart. 2017 River Stone Legacy 38MB 2001 T2000 Kenworth 2009 Smart Passion ET Junior hitch Link to comment Share on other sites More sharing options...
phoenix2013 Posted April 21, 2019 Report Share Posted April 21, 2019 The pins are available from McMaster 10 for $7 bucks https://www.mcmaster.com/98306a381 I put these in the vise and grind down the end with the spring hole to about 1/8" thickness to allow for easier spring installment. The springs are available in any Ace hardware store, they have a spring assortment in their hardware section, it is distributed by Hillman part number #169 Link to comment Share on other sites More sharing options...
dblr Posted April 22, 2019 Author Report Share Posted April 22, 2019 Thank you Henry, appreciate the help 2017 River Stone Legacy 38MB 2001 T2000 Kenworth 2009 Smart Passion ET Junior hitch Link to comment Share on other sites More sharing options...
jeffw Posted April 23, 2019 Report Share Posted April 23, 2019 https://www.amazon.com/CENTURY-SPRING-C-191-Extension-Spring/dp/B000BQO07W 2 pack, 3/4" OD, extension spring, 3-3/4" length, .105" wire diameter, 1.39" maximum deflection, 46.2 lbs maximum safe load, polybag. 2007 Volvo 780 Volvo D12D, 465hp, 1650 ft/lbs tq., ultrashift Link to comment Share on other sites More sharing options...
phoenix2013 Posted April 23, 2019 Report Share Posted April 23, 2019 1 hour ago, jeffw said: https://www.amazon.com/CENTURY-SPRING-C-191-Extension-Spring/dp/B000BQO07W 2 pack, 3/4" OD, extension spring, 3-3/4" length, .105" wire diameter, 1.39" maximum deflection, 46.2 lbs maximum safe load, polybag. These should work too, same spec spring Link to comment Share on other sites More sharing options...
