GlennWest Posted December 12, 2017 Report Share Posted December 12, 2017 As many know on here, I installed a mini split system in our Teton. Our Bedroom AC/heatpump not been used since. It needed a compressor fan. I removed it today and patch opening. Found out not really any way to keep roof material stretched without an anchor point. Small patch so wrinkles shouldn't be a problem. Disappointing but only airplanes will see it. lol. This opens up a large area on front for solar later. 2003 Teton Grand Freedom towed with 2006 Freightliner Century 120 across the beautiful USA welding pipe.https://photos.app.goo.gl/O32ZjgzSzgK7LAyt1 Link to comment Share on other sites More sharing options...
spindrift Posted December 12, 2017 Report Share Posted December 12, 2017 Glenn...I didn't realize you're supposed to stretch the roofing material. 2012 F350 KR CC DRW w/ some stuff 2019 Arctic Fox 32-5MCindy and Tom, Kasey and Maggie (our Newfie and Berner) Oh...I forgot the five kids. Link to comment Share on other sites More sharing options...
Chalkie Posted December 12, 2017 Report Share Posted December 12, 2017 10 hours ago, GlennWest said: As many know on here, I installed a mini split system in our Teton. Our Bedroom AC/heatpump not been used since. It needed a compressor fan. I removed it today and patch opening. Found out not really any way to keep roof material stretched without an anchor point. Small patch so wrinkles shouldn't be a problem. Disappointing but only airplanes will see it. lol. This opens up a large area on front for solar later. If it was a standard roof opening why not install a vent? Just curious. Link to comment Share on other sites More sharing options...
GlennWest Posted December 12, 2017 Author Report Share Posted December 12, 2017 Mine is ducted. No inside opening. Also main reason for removing is to open up top for solar later. Acs cause shading and limit area. 2003 Teton Grand Freedom towed with 2006 Freightliner Century 120 across the beautiful USA welding pipe.https://photos.app.goo.gl/O32ZjgzSzgK7LAyt1 Link to comment Share on other sites More sharing options...
oldbutspry Posted December 13, 2017 Report Share Posted December 13, 2017 Do you have any pics of what the opening looked like after removing the AC? Just curious what the innards look like. Link to comment Share on other sites More sharing options...
GlennWest Posted December 13, 2017 Author Report Share Posted December 13, 2017 Sorry, didn't take any. It was 14 1/2" square opening. Plastic baffle under it for flow direction. After removing unit had to remove baffle also. then patch ductwork. We still using rear ac. 2003 Teton Grand Freedom towed with 2006 Freightliner Century 120 across the beautiful USA welding pipe.https://photos.app.goo.gl/O32ZjgzSzgK7LAyt1 Link to comment Share on other sites More sharing options...
