INWsters Posted October 31, 2017 Report Share Posted October 31, 2017 Woohoo! Brought our new to us, first time in the deep end (dark side) 2000 Volvo 610 home today. Bought it needing some work, took it straight to the truck shop, had it taken care of and now it's almost ready to go. Needs some serious elbow grease inside and out as it was a rodeo rig - still has hay, arena dirt and bovine exhaust, etc. attached. It has a C7 Air Ride Hitch for gooseneck that doesn't appear to be in production any longer so no info. Toyhauler has a 5th Airborne pin box, so researching whether to go ET hitch, TS hitch or convert trailer pin box to gooseneck and use existing air hitch. I keep thinking "Holy Crap! We bought a semi!" Wife is totally on board though, she's been more skeptical of our F350's ability to pull - and stop - it, than I have been. Took the fiver and F350 out this weekend and was totally reminded why we bought the HDT. It's gonna be the cats pajamas next year. Immediate concern however, is the row of empty bolt holes I found around the perimeter of the mid rise fairing on the truck tonight. They appear to be mounting holes for a high rise fairing that would attach to the mid rise. They have no bolts in them, so my question is - are these a water intrusion problem or blind holes? If I need to seal them, are bolts, washers and some rtv silicone sufficient to prevent water getting in on top of the headliner? If not, how to best seal them up and have a cosmetically acceptable result? Thanks again for all advice and help, looking forward to seeing fellow HDTer's on the road. Link to comment Share on other sites More sharing options...
ARGO Posted October 31, 2017 Report Share Posted October 31, 2017 Mine are all dead holes, no leaks. I'd get up there & poke something in there to be sure. Some "technician" may have run a 3" long bolt in one sometime................ Link to comment Share on other sites More sharing options...
Av8r3400 Posted October 31, 2017 Report Share Posted October 31, 2017 My 730 has these holes also, but never had the upper doghouse installed. They are capped with little plastic caps color matched (mostly) to the truck. I'd look for them at either your Volvo dealer or maybe a "Fastenall" type hardware business. Link to comment Share on other sites More sharing options...
Jack Mayer Posted October 31, 2017 Report Share Posted October 31, 2017 You can cap them with the plastic caps. Or you can fill them with color-matched caulk....I filled the ones on my white 610 with white silicon caulk, and added the caps on top. They stayed in place and looked "OK" for 10 years. Link to comment Share on other sites More sharing options...
INWsters Posted November 1, 2017 Author Report Share Posted November 1, 2017 Thanks for the info, I'll check to see if I can source the caps. Good call on checking each hole Argo. Link to comment Share on other sites More sharing options...
