Grassy Posted June 6, 2017 Report Share Posted June 6, 2017 To set or find out what is happening with your ultrashift trans..you have to go to a dealer who plugs in their laptop with the Eaton software running.. Is the right cable and software available to the public and do I need to sell my first born to buy it ? And has anyone done this ? Thanks.. . Arctic Fox 29-5T . Beagle co-pilots - Faffy and Lulu Link to comment Share on other sites More sharing options...
MrSeas Posted June 6, 2017 Report Share Posted June 6, 2017 Yes you can....... software is available especially for the earlier models of the UltraShift. You do need a computer running WIN 7 and the interface box to connect the computer to the trucks 9 pin connector. It's all doable but the cost/ benefit ratio is not very favorable. The changes you can apply to the trans software is limited based on firmware of the trans computer box. It's cost effective to find a shop that has the " Road Ranger" software and interface box to make any changes. I have a 2005 model UltraShift and all I could change was the "starting gear". I can now start off in any gear 2-5. No other changes were available in my particular set up. Link to comment Share on other sites More sharing options...
GeorgiaHybrid Posted June 6, 2017 Report Share Posted June 6, 2017 The newer Ultra Shift plus has quite a few options involving starting gears, shift points, clutch pedal options and others that can be configured. For an hours worth of time, you can set them once and forget it a lot cheaper than the cost of the software. 2017 Kenworth T6802015 DRV 38RSSA Elite Suites2016 Smart Prime Link to comment Share on other sites More sharing options...
