Truck Fridge Cooling Fans
SuiteSuccess
My last truck fridge (Lowes Magic Chef Dorm) croaked after 5 years.  Not bad for only paying $108.  Replacing with Heir 3.1 cu/ft.  After talking to RandyA added some exhaust fans to improve circulation.  Used two muffin fans tied in with a snap disc thermostat which comes on at 100* F and off at 85* F.  Also mounted a switch on dash just in case I want to be sure fans are off when fridge not being used.
Placed fans in between panels at vents
http://i.imgur.com/KuY2MjFl.jpg
Muffin fans from old computer.
http://i.imgur.com/pZmFkS9l.jpg
http://i.imgur.com/BawQ0YNl.jpg
Snap cap thermostat.
http://i.imgur.com/Qe7mdDSl.jpg
Used my heat gun to activate thermostat and all worked as it should.  I'm happy.
2017 DRV 39DBRS3
Dang it images not showing up.  Help!
2017 DRV 39DBRS3
RickS,
Thanks. How did you do that?
2017 DRV 39DBRS3
Rick beat me by half a second :)
2014 smart Fortwo
2 minutes ago, RickS said:
In the bottom right corner of the reply box is a "Insert other media"  choose "insert image from URL" and use your url address starting with the http:// and ending with .jpg
Ok thanks again.
2017 DRV 39DBRS3
Or, if you have pictures in a Google Photos library you can just "copy image" in the album, and do a paste into the reply.  Really easy.  It took me literally 3 seconds to do the one below.
1I6PKWZ_Dm6lSw46NXcjxk2DB70dUhxJQkcoGHEPWmn_GAnBHrSDGeammB65E3NILHFuC40AqRATyA6oSTc0Rg4ci84lHlpPqeX5_6hWq32eJdTYyWcVMOTJbl-5TpK65ErmaD1nnmci1lHojEueiL5gTdzRwC73N6HT8egYxINSbfF1UFL5guZ5AZSyPvjDOXXTu9Bk_ZHuc1dyxziXSTJwYTjiN2kGrjiZFdD8KDhS3bJv6E7z3SyEpyWhOH78ioNty8zsjWfL9jluhGakz9ZLZ1YDQUDdRa-9oRsuKu_ylJrKcF_4n3M1xzSPHTDlvf-032PUcyNdZSMN6ANDT5r47igaXfjdBedCl-R5xi_fh4kxvMsX0ZGLLLjCXyOsiInA2OYoG4eqbZ8kPIKj2evJ-7rSH9CiEoxssOKA3FII75VawLD8xB3Dfs3bqtQGkypB_6ravhBFv9IezFHnWxJHHgJ_fUimS8plQfoywIPQ_bT5FVydZ9VZJVUq0JMC4o4H6v16NiaYA4EqAMQ2fuyd778gLUFiAR4ezsbKmvk8o_uFALS45DOF0mv0EQNcmr5hUgzDxJCe5T0Wt2CZ5d-2rxOYLvfhwOhjehF5rGyAA6ff27JkttiFzsnyRmVAg2DfMX3st_XeVpOg6A5_xOdgKNcdF1w2RHH4et4SdLc=w1227-h919-no
Living on the road since 2000
2022 New Horizons 43' 5er
2016 Itasca 27N 28' motorhome
www.jackdanmayer.com
Thanks Jack.  Got it.  Will try that.
2017 DRV 39DBRS3
On 100* and off at 85*.  I researched the Camco fridge fans and they have same parameters.
2017 DRV 39DBRS3
