runaway parents Posted May 26, 2017 Author Report Share Posted May 26, 2017 21 hours ago, rdickinson said: I'm thinking Coreplast, corrugated cardboard and stowing them under the mattress. Light, easy to handle, any color. I pack enough lumber as it is. Where were you when we were replacing a rotted out floor and hanging trusses last month? Lotsa fun. Wow what a project done a lot of projects like these over the years mainly commercial work. Link to comment Share on other sites More sharing options...
rdickinson Posted May 26, 2017 Report Share Posted May 26, 2017 Louisiana. Plumber hadn't crimped one connector to the shower mixer valve. Steady drip for 5 yrs, rotted out OSB floor under laminate flooring plus plates and trusses as you can see Lotsa mould, I was spraying everything with Shockwave. Laminate floor was ok, it was protected by foam under. Rich stepped on rotten section and foot went thru floor and the laminate floor sprung back trapping his leg. We had to skillsaw the floor to get him out. If you're available next build trip we could sure use the help. Basically fixing up less than stellar work. Depending on location, may be able to get accommodation free or at a discounted rate. This was as bad as it gets, most are pretty easy. Tools and material supplied. Link to comment Share on other sites More sharing options...
