Ronbo Posted May 21, 2017 Report Share Posted May 21, 2017 I saw a small cover on the same side as the reset button and lifted it up. I found a USB connection. I did not apply power as I had just built a OBD II connector. I tried to post a picture but it won't allow it. Ron C. 2013 Dynamax Trilogy 3850 D3 2000 Kenworth T2000 Optimus Prime Link to comment Share on other sites More sharing options...
BlueLghtning Posted May 21, 2017 Report Share Posted May 21, 2017 You can actually use that USB port to tether it to certain routers. People are doing that for their home internet. There's some threads over on Howard Forums about it. There's also some antenna ports hidden on the hardware if you totally take it out of the plastic. It take a really weird antenna adapter, but people are using that to use external antenna's on theirs. Dan (Class of 2017) - 2012 Ram 3500 & 2005 Alpenlite Valhalla 29RK Contact me at rvsolarconsulting.com or Two Wheel Ramblin Link to comment Share on other sites More sharing options...
Mark and Dale Bruss Posted May 21, 2017 Report Share Posted May 21, 2017 Dongle connection is not always better that a WiFi Connection. I had a Pantech MiFi unit and the WiFi using WiFi as WAN was 10 times faster that the USB cable connection. Having a WiFi as WAN router means you can easily use Park WiFi as well and the Mobley. Please click for Emails instead of PM Mark & DaleJoey - 2016 Bounder 33C Tige - 2006 40' Travel SupremeSparky III - 2021 Mustang Mach-e, off the the Road since 2019 Useful HDT Truck, Trailer, and Full-timing Info atwww.dmbruss.com Link to comment Share on other sites More sharing options...
Ronbo Posted May 21, 2017 Author Report Share Posted May 21, 2017 I believe it is a micro USB port. I tried my cord for my mifi but it was a loose fit and wouldn't power up. It may be for updating. Ron C. 2013 Dynamax Trilogy 3850 D3 2000 Kenworth T2000 Optimus Prime Link to comment Share on other sites More sharing options...
Dutch_12078 Posted May 22, 2017 Report Share Posted May 22, 2017 4 hours ago, Ronbo said: I believe it is a micro USB port. I tried my cord for my mifi but it was a loose fit and wouldn't power up. It may be for updating. You can't use the Mobley USB port to power it, but as BlueLghtning said, it can be used as a data port when connected to certain routers. Dutch 2001 GBM Landau 34' Class A F-53 Chassis, Triton V10, TST TPMS 2011 Toyota RAV4 4WD/Remco pump ReadyBrute Elite tow bar/brake system Link to comment Share on other sites More sharing options...
