tinstartrvlr Posted November 5, 2016 Report Share Posted November 5, 2016 Greetings everyone! I have seen it mentioned before that a leak test should be done anytime there is an "interruption" in the propane system. The way I have seen it put is that the whole system needs to be leak checked after doing work anywhere in the system. I am going to replace a gas bottle supply pigtail, and other than checking for leaks at the fitting, why would I need to check the whole system after I finish? Or am I just reading this all wrong? Thanks. Ya just can't RV without a hitch.....! Link to comment Share on other sites More sharing options...
HamRad Posted November 5, 2016 Report Share Posted November 5, 2016 Greetings everyone! I have seen it mentioned before that a leak test should be done anytime there is an "interruption" in the propane system. The way I have seen it put is that the whole system needs to be leak checked after doing work anywhere in the system. I am going to replace a gas bottle supply pigtail, and other than checking for leaks at the fitting, why would I need to check the whole system after I finish? Or am I just reading this all wrong? Thanks. Just check the part or section that was changed or compromised. No need to test entire system. The only testing we do is to listen very carefully when we reattach the tank to the rig. We did some work on HWH and did do a water test. But won't have to do that again unless we notice some problem. Good luck. Dennis Trailer: Montana 5th wheel, model 3582Rl, model year 2012 Truck: Ford 450 PSD Super Duty, 2002 Crew Cab, Long bed, 4:88 rear end, last of the 7.3 engines, Automatic Transmission. Link to comment Share on other sites More sharing options...
tinstartrvlr Posted November 5, 2016 Author Report Share Posted November 5, 2016 Thanks Dennis,,,that makes sense. I'll just worry about the one fitting. Ya just can't RV without a hitch.....! Link to comment Share on other sites More sharing options...
gjhunter01 Posted November 6, 2016 Report Share Posted November 6, 2016 The way you would test the entire system is to install a pressure gage, allow gas to enter the entire system and then shut off the propane tank supply. The pressure gage needs to hold pressure more than 5 minutes. If you are working on the system your self, just check any connections with a soapy water solution. If a service repairman is to work on or charge a empty residential system, Texas law requires the entire system be checked for leaks. Greg Link to comment Share on other sites More sharing options...
Kirk W Posted November 6, 2016 Report Share Posted November 6, 2016 If you really want the instructions on the proper means of testing the propane system for leaks, read the description of the timed pressure drop test from the RV doctor. Good travelin !...............KirkFull-time 11+ years...... Now seasonal travelers.Kirk & Pam's Great RV Adventure Link to comment Share on other sites More sharing options...
oldjohnt Posted November 6, 2016 Report Share Posted November 6, 2016 Even if an entire system test may not be absolutely necessary it wouldn't hurt to perform one to be on the safe side. Of course the most important thing is to check any NEW fittings and appliances including a leak down pressure check. In addition, I recently went to Ace Hardware and bought a small spray bottle of gas leak detector which can detect leaks, simple cheap n easy in addition to a total leak down if required. John T Live from the Florida Flywheelers Antique Tractor Show Link to comment Share on other sites More sharing options...
ms60ocb Posted November 6, 2016 Report Share Posted November 6, 2016 Of course if you have the $$$ this instrument will find the leaks after the pressure test fails. I saw this on this Board the HDT Forum http://www.rvnetwork.com/index.php?showtopic=125479 Clay Clay & Marcie Too old to play in the snow Diesel pusher and previously 2 FW and small Class C Link to comment Share on other sites More sharing options...
