alan0043 Posted August 1, 2016 Report Share Posted August 1, 2016 Hi Everyone, I am working on a 2012 VNL 630. I have the need to remove the dog house and lower dash parts. On the dog house I have removed the 4 bolts located on the floor. The dog house will not move. I have opened the hood and looked for bolts under the hood. I did not see any bolts under the hood. I have a feeling that I need to remove some lower dash parts to get the dog house out. I have also removed some screws from the lower dash that I could see. What are some of the tricks and location of fasteners that I can not see. I do not want to force anything. I have removed lower dash pieces from a gen 1 with not much trouble but the gen 2 seems to be a little more difficult. Looking for help, Al Link to comment Share on other sites More sharing options...
Jim & Wilma Posted August 1, 2016 Report Share Posted August 1, 2016 On the top of the Doghouse against the firewall there's two bolts holding a bracket that secures the top "lip" of the Doghouse. It's a pain to reach, and if I recall, I used a couple ratchet extensions and a swivel joint. Link to comment Share on other sites More sharing options...
Jim & Wilma Posted August 1, 2016 Report Share Posted August 1, 2016 I might also mention that I decided to remove the Doghouse after I found some water leaking in when I directed hose at the joint from the engine compartment. I suspect this "test" greatly exaggerated what the joint might see driving through puddles and the like. Anyway, I proceeded with removal in expectation of replacing the gasket. Local Volvo didn't carry the gasket so I gave the gasket a boost by shoving 3/16" Dacron rope under the gasket and sealing it in with some Loctite PL3X polyurethane caulk. Turned out very effective at sealing against hose directed leaks . . . and it was cheap! Link to comment Share on other sites More sharing options...
alan0043 Posted August 1, 2016 Author Report Share Posted August 1, 2016 Hi Jim, Have you ever removed the lower dash parts above the dog house ? I think if I can remove those pieces, that it could be easier to see those top bolts that you where talking about. I also have a need to remove the whole lower dash parts. I am thinking about changing there color. Al Link to comment Share on other sites More sharing options...
Jim & Wilma Posted August 1, 2016 Report Share Posted August 1, 2016 Yes, I removed the lower dash plastic components. There was also an abandoned satellite comm box that I removed to gain access and it was still a pain. Link to comment Share on other sites More sharing options...
alan0043 Posted August 1, 2016 Author Report Share Posted August 1, 2016 Yes, I removed the lower dash plastic components. There was also an abandoned satellite comm box that I removed to gain access and it was still a pain. Was there any tricks about the lower dash pieces ? Are the bolts that need to be removed right in front of you ? Is there any hidden bolts ? Al Link to comment Share on other sites More sharing options...
Big5er Posted August 1, 2016 Report Share Posted August 1, 2016 Alan, I took the small "shelf" out that sits above the dog house. Those screws are real obvious if you lay on your back and look up...think there is one in the back too. After that you can see the top of the doghouse and the bolts that are back there going into the firewall. Link to comment Share on other sites More sharing options...
alan0043 Posted August 3, 2016 Author Report Share Posted August 3, 2016 Alan, I took the small "shelf" out that sits above the dog house. Those screws are real obvious if you lay on your back and look up...think there is one in the back too. After that you can see the top of the doghouse and the bolts that are back there going into the firewall. Hi Phil, Thank you for tip. I found out on my truck that they replaced the two screws on the top with two clips up that are up front. There where no screws or clips in the back of the shelf. Getting to the top two bolts on the dog house where a pain in the a$$ just like Jim said. The hard part is yet to come. That is putting the two top bolts back into the top of the dog house. Al Link to comment Share on other sites More sharing options...
SIBERNUT Posted August 3, 2016 Report Share Posted August 3, 2016 I changed out the whole dash in mine. Note there are 2 bolts under the speaker grills you might not expect................................ Link to comment Share on other sites More sharing options...
