Walking thunder Posted July 1, 2016 Report Share Posted July 1, 2016 Any smart weigh gurus out there? I recently went to a public scale to weigh. I asked if I could do each side separately and was given the go ahead. When I got the ticket it only showed 2axels. I was told even though I had each axel on a separate scale pad that they couldn't do each axel separately. I'm quite always away from a smart weigh location. Any thoughts? 2015 Cardinal 3850RL F350 KingRanch using B&W Companion Hitch And my funny little dog DOVES Member Link to comment Share on other sites More sharing options...
Kirk W Posted July 1, 2016 Report Share Posted July 1, 2016 Makes me wonder about the scale operator. What scale did you weigh on and where located? It is possible as there are scales that only give one weight. But with two axle weights and 4 axles? That is really strange. Do the weights add up to a reasonable amount for the total of your truck and trailer? Might it be that you have a weight for the truck and one for the trailer? Good travelin !...............KirkFull-time 11+ years...... Now seasonal travelers.Kirk & Pam's Great RV Adventure Link to comment Share on other sites More sharing options...
Dennis M Posted July 1, 2016 Report Share Posted July 1, 2016 This Cat Scale page might be some help with the axle splits, but won;t help with the side to side. Dennis & NancyTucson, AZ in winter, on the road in summer.1999 Volvo 610 "Bud" 425 HP Volvo, Super 10 spd.2005 Mountain Aire 35 BLKS2013 smart fortwo CityFlame riding on Bud(Replaced '05 smart first loaded in '06 and '11 smart that gave it's life to save me!)Our Travel Blog Link to comment Share on other sites More sharing options...
Walking thunder Posted July 1, 2016 Author Report Share Posted July 1, 2016 Thanks. I went to a non CAT scale. I think until I can get to a smart weigh location that will have to do. 2015 Cardinal 3850RL F350 KingRanch using B&W Companion Hitch And my funny little dog DOVES Member Link to comment Share on other sites More sharing options...
rdickinson Posted July 2, 2016 Report Share Posted July 2, 2016 I had an opportunity to weigh the rig today. Scales were closed, Holiday. Anyway the kitchen or non door side is 900 lbs heavier than the diningroom slide. It is 3' longer and houses the residential fridge, cabinets and Corian tops. I don't think there is any way to equalize the weights. There isn't enough stuff to move that would make 450 lbs difference. Maybe it's supposed to be like that and made to take the weight. Input? Link to comment Share on other sites More sharing options...
Mark and Dale Bruss Posted July 2, 2016 Report Share Posted July 2, 2016 My 40' Travel Supreme is 1000 heavier on the street side which has three slides and the kitchen. You are right there is not much you can do to balance the weight. But the heavy side will determine the tire load rating you need and the pressure that is needed. Please click for Emails instead of PM Mark & DaleJoey - 2016 Bounder 33C Tige - 2006 40' Travel SupremeSparky III - 2021 Mustang Mach-e, off the the Road since 2019 Useful HDT Truck, Trailer, and Full-timing Info atwww.dmbruss.com Link to comment Share on other sites More sharing options...
rdickinson Posted July 2, 2016 Report Share Posted July 2, 2016 The tires are 17.5 H rated Hancooks and upgraded hubs. I have the axle(s) wt, rear truck and front axle wt. Just need to get the pin wt next week at a set of scales that are no longer in use. Link to comment Share on other sites More sharing options...
Walking thunder Posted July 3, 2016 Author Report Share Posted July 3, 2016 I went to a cat scale and re weighed. 5040 front axel. 6700 rear and 12740 trailer. According to ford my f350 max gcvw is 23,000. I'm 24,480. 1400 too heavy. I'm a full timer but not a pack rat. New truck or loose some weight? Guess the washer dryer I wanted is out of the question. ? 2015 Cardinal 3850RL F350 KingRanch using B&W Companion Hitch And my funny little dog DOVES Member Link to comment Share on other sites More sharing options...
jjwicklund Posted July 3, 2016 Report Share Posted July 3, 2016 I went to a cat scale and re weighed. 5040 front axel. 6700 rear and 12740 trailer. According to ford my f350 max gcvw is 23,000. I'm 24,480. 1400 too heavy. I'm a full timer but not a pack rat. New truck or loose some weight? Guess the washer dryer I wanted is out of the question. Check the DW'S SHOE collection, I have to keep an eye on mine. John 2017 F350 King Ranch DRW 6.7 4.10 B&W hitch 2017 DRV MS 36RSSB3 Link to comment Share on other sites More sharing options...
Walking thunder Posted July 3, 2016 Author Report Share Posted July 3, 2016 Lol. Just me and the dog. If the x were around it would b another 2-3k #. Guess I need to start considering a DRW 2015 Cardinal 3850RL F350 KingRanch using B&W Companion Hitch And my funny little dog DOVES Member Link to comment Share on other sites More sharing options...
Alie&Jim's Carrilite Posted July 3, 2016 Report Share Posted July 3, 2016 New to you truck..... HDT time!!!! There are several available to choose from in the for sale section. Alie & Jim + 8 paws 2017 DRV Memphis BART- 1998 Volvo 610 Lil'ole 6cyl Cummins Link to comment Share on other sites More sharing options...
vt3fan Posted July 4, 2016 Report Share Posted July 4, 2016 We had the very same problem with weight and F350. We moved to a F350 DRW and it solved the problem- at least as far as GCW is concerned. Rick & Mary Sorensen Molly - Boston Terrier 2016 Ford F350 DRW 6.8 L diesel 2016 Mobile Suites 36RSSDB3 Full Timers w/ SD Residency Link to comment Share on other sites More sharing options...
Mike and Claudia Posted July 5, 2016 Report Share Posted July 5, 2016 While driving through RURAL AMERICA, keep you eyes open for "Elevators" IE: tall, multi-round usually cement structures that look a lot like gigantic paper towel rollers. These are usually situated near (very near) railroad tracks. They will have a rectangular weight area. You can (usually) drive each wheel onto the weight area while leaving the others OFF of the scale. If not, with a 5-er you can roll front tire, weigh--next two together, and if applicable, three tires. Then turn around and do the opposite. This method requires some addin' and subtractin'. On a MH I can drive each wheel(s) on the scale. In Texas, they are more than happy to help you out with the job. In my home town, they charge $ 5.00 that goes into the morning DONUT kitty. If you get there early enough, you cn even get in on the donuts and coffee. Just be polite and try to act like a "good ole boy". ;~)) Traveling America in "God's Grace" Link to comment Share on other sites More sharing options...
