rbertalotto Posted June 1, 2016 Report Share Posted June 1, 2016 Is anyone using this device to see propane levels http://www.campingworld.com/shopping/item/lpg-tank-check-dual-sensor-with-monitor-kit/90403 Looks like a great device. I'm currentl;y using a TRUMA Level Check http://www.levelcheck.com/us/ but it requires taking the cover off the tanks which I'd like to find an easier method. RoyB South of Boston 2021 Dodge 2500 - 6.4L Forest River 19RR Toy Hauler Roofnest Falcon Rooftop Tent www.rvbprecision.com Link to comment Share on other sites More sharing options...
rdickinson Posted June 1, 2016 Report Share Posted June 1, 2016 I have it, got it at the Tampa RV show in January. Seems to work fine. I needed one of their people to walk me thru calibrating it. The sponge spacers provided fall off the rim on the bottom of the tank so best get some RV door gasket and stick it on the bars under the tank. The tank needs to be isolated from metal under, I think. Also make sure it is located correctly on the bottom of the tank. I put the receiver in the electrical panel. Link to comment Share on other sites More sharing options...
rbertalotto Posted June 1, 2016 Author Report Share Posted June 1, 2016 Thanks for the feedback! Are you using your phone to read it or did you get the little monitor panel? RoyB South of Boston 2021 Dodge 2500 - 6.4L Forest River 19RR Toy Hauler Roofnest Falcon Rooftop Tent www.rvbprecision.com Link to comment Share on other sites More sharing options...
rdickinson Posted June 1, 2016 Report Share Posted June 1, 2016 I got the monitor panel and fixed it into the main electrical panel area. All that needs to be done is push the two buttons to check fluid level. HI tech isn't needed. You get the whole 3 part kit for 125$. www.approducts.net is what is on the xtra sender I have. Link to comment Share on other sites More sharing options...
K5RCD Posted June 16, 2016 Report Share Posted June 16, 2016 Beware the Truma Level Check. I purchased one from the manufacturer's website. It is a piece of junk that didn't work from the get go. Following the directions to the letter, I tried to use it to check the level of several different full tanks. It read empty on all, except for one instance when it correctly indicated full, but only for a moment. Next time I check, it shows empty. I called the manufacturer hoping for a refund. The representative I talked to seemed amazed that it didn't work. She offered to e-mail me a return authorization form I could use to return it and receive a refund for the product and shipping (not cheap at $81 total). Well, I never received the authorization. I called again and was told it would be sent, but it never was, and no reply of any kind. They have my e-mail and phone number. I guess they were just trying to get me off the phone. I notice their website has no place for product reviews, and now I can see why. My recourse is to dispute the charges when they show up on my credit card, which I will do. In any event, I advise y'all to stay away from this useless hunk of garbage, and the phony offer of refund. Sorry for the rant, but I've had it with lack of service and lies from crummy companies on the market these days. Link to comment Share on other sites More sharing options...
Yarome Posted June 16, 2016 Report Share Posted June 16, 2016 Beware the Truma Level Check. Hmm. Mine works perfectly. You DO have to ensure the device is level and sensor pressed firmly to the tank, but has never failed me. The first dozen or so times I double checked it with a tank scale and it proved to be highly accurate. As Roy said.. it's a little bit of a bother to have to remove the tank cover to get a reading, but it's sure more convenient than having to loosen and tighten a tank for weighing. I'm extremely pleased with mine. It's great to have accurate daily readings to really see what you're 'actually' burning and takes a lot of guesswork out of planning a refill. I haven't really seen any of the AP sensors in action, so can't comment, but there doesn't seem to be much out there in the way of reviews and did notice that a couple of places have them listing as "clearance sale" items. Not enough demand to justify the cost? Failing to meet expectations? Dunno. If it works as advertised, that's a whole 'nother level of monitoring that I would bet a lot of full/most-timers would really appreciate. Link to comment Share on other sites More sharing options...
Kirk W Posted June 17, 2016 Report Share Posted June 17, 2016 Has anyone used the Camco add-on gauge? I have thought of replacing my old magnetic with one of these. Good travelin !...............KirkFull-time 11+ years...... Now seasonal travelers.Kirk & Pam's Great RV Adventure Link to comment Share on other sites More sharing options...
Yarome Posted June 17, 2016 Report Share Posted June 17, 2016 Has anyone used the Camco add-on gauge? I have thought of replacing my old magnetic with one of these. Personally, given those 2 choices, I would stick with your magnetic strip. It's much more accurate and gives you the ability to check actual LP levels at any given time. The main problem I see with those pressure type gauges is that they really only tell you when you're "full" (probably), "low" (really?? Oh.. nope!) or "you're out of fuel in 5 minutes". You've been in the game long enough to know how much 'at valve' pressures can vary based on ambient temps and temp variations that occur when a tank is actually in use. Gauges like that will fluctuate up and down accordingly with no real basis on how much LP is actually in your tank. Some folks have mentioned that the additional restriction has caused problems with higher demand LP devices. Personally, I think it's all in their head since regs just aren't 'that' sensitive to pressure fluctuations from the tank. More than likely a regulator issue, but it's not uncommon to hear folks mention that. Sitting static, taking into account the local temps and recent usage.. it'll give a fairly "ok" idea of where you sit. Is it more convenient that pouring a little warm water.. likely.. but with your strip.. you'll KNOW a 1/4 tank is a 1/4 tank. IMO, if you're tank didn't come with one there just isn't enough practical benefit to justify the cost. For the 20 bucks.. I'd rather eat steak. Link to comment Share on other sites More sharing options...
Alie&Jim's Carrilite Posted June 17, 2016 Report Share Posted June 17, 2016 Has anyone used the Camco add-on gauge? I have thought of replacing my old magnetic with one of these. I use one on the separate 20lb tank we carry for the grill. Works as advertised. For our situation though we don't have enough room in the compartment for 2 of the gauges and for them to be readable. Jim's Adventures Old Spacecraft.... Who knows whats next Link to comment Share on other sites More sharing options...
PAylor Posted June 18, 2016 Report Share Posted June 18, 2016 We also bought one at the Tampa show and love it! We have the one that uses an app on the cell phone. I believe it was about $40 for one sensor. Highly recommend it. Link to comment Share on other sites More sharing options...
oscarvan Posted June 28, 2016 Report Share Posted June 28, 2016 Truma has been good to me, and, as I have two RV's, a propane fired fireplace in the S&B and a grill in the garage...... it's all over the place giving me answers. Previously a 2017 Forest River, Berkshire 38A, "The Dragonship". https://dragonship.blog/ Link to comment Share on other sites More sharing options...
K5RCD Posted June 29, 2016 Report Share Posted June 29, 2016 Truma has been good to me, and, as I have two RV's, a propane fired fireplace in the S&B and a grill in the garage...... it's all over the place giving me answers. What does "it's all over the place giving me answers" mean ? Do you mean it gives inconsistent results, or it works in various locations? Link to comment Share on other sites More sharing options...
