rbertalotto Posted May 10, 2016 Report Share Posted May 10, 2016 Dual post RoyB South of Boston 2021 Dodge 2500 - 6.4L Forest River 19RR Toy Hauler Roofnest Falcon Rooftop Tent www.rvbprecision.com Link to comment Share on other sites More sharing options...
rbertalotto Posted May 10, 2016 Author Report Share Posted May 10, 2016 I wanted to be able to charge my devices while I'm sitting outside under the awning. The easiest method was with this device. TOPGREENER TU21548A 4.8A Duplex USB Charger Outlet Simply replaced my duplex with this device...Done! Upgraded High Speed Charging Tech: World's First Smart Ultra-High Speed Dual USB Charging In Wall at 4.8 Amp, 24W, 5VDC Charging-Smart Technology: Dual "Smart" USB Ports Precisely "Read" the Power Need then Maximize Charging Efficiency Design Innovation: Interchangeable Face Cover. 3 Color Face Cover Included: White, Black, Light Almond Two TR Tamper-Resistant Outlets enhance electrical safety, preventing the attempting to insert objects into the outlet; Meets 2011 NEC Compatibility USB 1.1/2.0/3.0 devices, 2 USB ports total 4.8 Amp, 5VDC; Two TR Receptacles 15 Amp/125VAC; UL lsted; 2 years warranty; Back & side wiring easy installation. Wall plate not included About $20 on amazon http://www.amazon.com/TOPGREENER-TU21548A-Resistant-Receptacle-Interchangeable/dp/B01BTC5I5O?ie=UTF8&psc=1&redirect=true&ref_=oh_aui_detailpage_o01_s00 RoyB South of Boston 2021 Dodge 2500 - 6.4L Forest River 19RR Toy Hauler Roofnest Falcon Rooftop Tent www.rvbprecision.com Link to comment Share on other sites More sharing options...
Darryl&Rita Posted May 10, 2016 Report Share Posted May 10, 2016 Couple comments: 1. It appears you removed a GFCI receptacle to install the USB style. Bad idea, unless you added a GFI breaker to the panel feeding that circuit. 2. Those USB power ports are live, as long as 120 power is applied to the circuit. When trying to reduce "phantom loads" during boondocking times, this is a negative outcome. I prefer the pug-in style power supply, so I can control when and where it's used. I have been wrong before, I'll probably be wrong again. 2000 Kenworth T 2000 w/N-14 and 10 speed Gen1 Autoshift, deck built by Star Fabrication 2006 smart fourtwo cdi cabriolet 2007 32.5' Fleetwood QuantumPlease e-mail us here. Link to comment Share on other sites More sharing options...
I'mdonewiththis forum Posted May 10, 2016 Report Share Posted May 10, 2016 Looking at the picture in the other thread I don't think the GFCI was removed. My trailer has the same style outlet outside but it is down stream from a GFCI inside. Link to comment Share on other sites More sharing options...
rbertalotto Posted May 10, 2016 Author Report Share Posted May 10, 2016 1. It appears you removed a GFCI receptacle to install the USB style. Bad idea, unless you added a GFI breaker to the panel feeding that circuit. Nope...It is simply GFI protected from the outlet next to the sink, inside. Standard, crappy, RV outlet with push on wire connection that was barely making contact when I removed it! 2. Those USB power ports are live, as long as 120 power is applied to the circuit. When trying to reduce "phantom loads" during boondocking times, this is a negative outcome. I prefer the pug-in style power supply, so I can control when and where it's used. When I'm hooked up to outside power, I really don't care about a few mW of phantom drain. But thanks for your concerns......it's appreciated. RoyB South of Boston 2021 Dodge 2500 - 6.4L Forest River 19RR Toy Hauler Roofnest Falcon Rooftop Tent www.rvbprecision.com Link to comment Share on other sites More sharing options...
oldjohnt Posted May 10, 2016 Report Share Posted May 10, 2016 rb, Ive seen those and as your exterior (as typical) receptacle is GFCI protected from the load terminal on your bathroom GFCI receptacle, it looks great to me. Also, it appears to have some degree of "smart" charging technology I highly recommend. I have seen instances where 12 VDC automotive cigarette lighter to 5 VDC USB charge ports (NOT so smart) have overcharged devices. John T Link to comment Share on other sites More sharing options...
