homelesshartshorns Posted March 8, 2016 Report Share Posted March 8, 2016 I use to have a map with location indicating "UF" I believe, that indicated shops that did work on basement air. That link has changed. Does anyone have such a resource? Link to comment Share on other sites More sharing options...
AFchap Posted March 8, 2016 Report Share Posted March 8, 2016 Try http://www.airxcel.com/coleman-mach/where-to-buy ... enter a zip and choose how many miles radius & you will get a list of dealers & service locations. I have learned to call first as many listed as uf tell me when I contact them "oh we don't work on the basement models." Link to comment Share on other sites More sharing options...
StarDreamers.us Posted March 8, 2016 Report Share Posted March 8, 2016 Thanks for the information. Safe Travels! Link to comment Share on other sites More sharing options...
wildmandmc Posted March 10, 2016 Report Share Posted March 10, 2016 Hey homeless. you still having issues with your a/c .? Link to comment Share on other sites More sharing options...
homelesshartshorns Posted March 16, 2016 Author Report Share Posted March 16, 2016 My Wife tells me I over think things too much. But I have some thoughts about the heat pump side of the unit. I understand if its too cold it does only gas heat and sometimes will do both but I find there is no rim or reason to when one or the other will come on. And I have had mornings when the compressor will start but almost eminently stop and go to gas. Its about time for air conditioning so I am guessing once I start that I might have to start thinking about it again.... Link to comment Share on other sites More sharing options...
Ray,IN Posted March 17, 2016 Report Share Posted March 17, 2016 It's logic within the unit that decides at what temperature to turn on your LP furnace, and whether to run both or shut off the heat pump immediately. A home unit works the same way. Link to comment Share on other sites More sharing options...
bobsallyh Posted March 22, 2016 Report Share Posted March 22, 2016 Here is how the basement heat pump on our Alfa fiver operates. It will operate down to about 38-40 degrees depending on the amount of humidity in the air, if the temp is lower it will defer to the gas furnace. When turning on the heat pump, check the temperature on the thermostat, move the "set temperature" for the heat pump down only 2-3 degrees below thermostat temperature. Turn on heat pump. Keep adjusting the "set heat" down approx. 3 degrees each time. If you take the "set temp" down a bunch of degrees at one time the heat pump will immediately defer to the gas furnace. We love our heat pump and basement air. Link to comment Share on other sites More sharing options...
