remoandiris Posted February 25, 2016 Report Share Posted February 25, 2016 I looked thru the HHRG but nothing jumped out. Is there a minimum "standard" distance needed between the hitch and Smart/RZR or is each setup different? Link to comment Share on other sites More sharing options...
Alie&Jim's Carrilite Posted February 25, 2016 Report Share Posted February 25, 2016 If your RV is 101" wide, then you need at least 51" inches. Most folks allow 60" or so for off camber turning, future hitch configurations, wider cars etc. Alie & Jim + 8 paws 2017 DRV Memphis BART- 1998 Volvo 610 Lil'ole 6cyl Cummins Link to comment Share on other sites More sharing options...
remoandiris Posted February 25, 2016 Author Report Share Posted February 25, 2016 Thanks. Pics I've seen are deceiving. Link to comment Share on other sites More sharing options...
phoenix2013 Posted February 25, 2016 Report Share Posted February 25, 2016 Here's what it looks like with 61 inches clearance at 90 degrees (yes, sooner or later you will find yourself at 90 degrees). Here's what happens in a turn. I cheated on my rig, needed a big drome, so my distance is around 55 inches, the rig is pretty close to the drom in a 45 degree turn. Also note, how I had to design double taper of the deck over the wheel wells. The previous setup didn't have it and this was the result on both sides of the rig in off camber turns. Link to comment Share on other sites More sharing options...
Dollytrolley Posted February 25, 2016 Report Share Posted February 25, 2016 Henry.............hanger-rash-for-trailer-trash...........kinda nice ring to it.......... Drive on.......(who put that deep sump drain where I was backing and......turning) 97 Freightshaker Century Cummins M11-370 / 1350 /10 spd / 3:08 /tandem/ 20ft Garage/ 30 ft Curtis Dune toybox with a removable horse-haul-module to transport Dolly-The-Painthorse to horse camps and trail heads all over the Western U S Link to comment Share on other sites More sharing options...
