Splendid Aristan washer and dryer
Big Greg
Greg,
We have that brand and model W&D in our 15' Mobile Suites. The brand is a Turkish Company and market major appliances in the US market through Major Appliance Distributors as well as a company in Oregon that distributes to the RV industry. . They have a good warranty and you can purchase an additional policy beyond the initial coverage if you wish. We did have a service call on our dryer (found out the DW over-loaded the dryer) and it caused the high-limit thermostat to go out. As long as you understand you are dealing on a smaller format than a regular W & D, you should be happy. The clothes come out of the dryer softer and fewer wrinkles than our old S&B Whirlpool dryer. Just make sure you use detergent with the "HE" label for front loaders. Currently we are using the "Persil" brand from Walmart and it works good.
If your washer runs forever, this can be caused by the drain hose being inserted too far into the drain. Customer service was no help. I called a tech and he told me to pull the drain back until only 6 inches was in the drain. If too much is inserted, it will just siphon the water back into the washer and will not register as having no water.
We have that same pair in our MS and they have never given us any trouble. Both of us liked the fact that we can be drying one load while washing another at the same time unlike a combo unit. The dryer and washer are not home units but do a very good job when you take into consideration the limits involved with a 120 volt dryer and small tub in a 24" washer.
