Help Loud Furnace Noise
Daveh
Hi all. The furnace ran fine overnight. It was still cold in here so I switched it on. Immediatley made a very loud noise, LOUD, sounded like a pump with no water or an air compressor. AC and fan work. Anyone have any ideas? Less than one year old. Dave
Was it blowing air? Did the propane light and air warm up? How long did you let it run? It could be that with everything cold it was just stiff and would loosen up and quite down with some run time. Have you heard it operate before in order to compare the sound to normal? An RV furnace is fairly loud as compared to other appliances and some don't like to use them at night for that reason. I'm thinking from your emphasis that it was louder than normal, but without hearing it I'm just guessing.
Hi Jim and Kirk. Kirk I had it running yesterday just fine. It typically isn't that quiet, but okay, but this was LOUD. MUCH louder than normal operation. Slight smell afterward although not smoke or electrical. No heat, no air flow. I thought it might be rubbing also Jim. Just weird because we have been stationary. Kirk it was so loud I hit the switch immediatley to shut it down. It ran a while longer as they do so probably one minute or so.
That does sound like some sort of abnormal blower obstruction. If it is the blower it will usually screech or some similar sound. It don't sound possible that it was off long enough for some bug to build a nest inside of the blower that supplies air to the burner? Mud dobbers are notorious for liking to build their nests in furnace blowers and that is really loud when they do. But that takes time to happen so I doubt that is the issue. It may be a loose blower as it has a squirrel cage type blower on each end of the motor shaft. One supplies the burner with outside air and the other moves air through the inside to heat it.
Did it possibly smell like burnt plastic ? When mine did this it ssounded like a cat squallering...lol and promptly melted the fan and housing together. I actually had trouble separating the housing to get the fan out due to the melted plastic. Mine at 1st just did it once in a while and I thought it was a bad bearing in motor. AC repairman friend of mine said old plastic and temp change plus original install were at fault
I had a loud noise from the heater fan and assumed it was a critter that had gotten into it. An RV shop pulled the unit and found the Squirrel Cage loose on the shaft and tightened it. I guess a Squirrel is a critter!
Northwood Reimbursed me for the repair since the 5er was under warranty.
Duct tape!
NOT on my furnace the squirrel cage is cheap and getting to it under the sink was not a picnic. On some models they come apart from outside on mine from the inside I had to remove doors under sink, the center brace and some paneling to get that lil jewel out. And my fan did not break it warped just enough to rub on housing.
  • 2 weeks later...
WELL, Took the fifth wheel to get checked because still under warranty. AND yes the problem was in the squirrel cage as many suggested. However, dead mouse in the squirrel cage so no warranty coverage. And the water heater needed to come out before they could get the furnace out. So 263 dollars later and the mouse is removed. How he got in there I have no idea. Maybe crawled up a tire, a cord or hose????No evidence of rodents otherwise. Any of you ever lay out traps???
I have used the old fashioned mouse traps with success, but if you don't know whether you have a mouse or not............... I don't believe that I have heard of a mouse in the fan before, but I suppose that anything has to have a first time. The price seems a bit excessive to me.
We had a crispy mouse in our furnace area once. Don't remember the symptom we had, maybe fan didn't come on - wouldn't stay lit , but it wasn't noise. DH was able to remove said critter and furnace then worked fine. Don't know how it got in there either.
Yes Kirk. It was high. I had it at Camping World thinking it was under warranty. They explained that the water heater had to come out before they could remove the furnace. Sooooo, just one of those things in life. I would have done the work myself if I knew the circumstances but....... Actually, I blame my schnauzer for letting a mouse romp around our trailer.
Found four mouse droppings in a drawer once..... Immediately deployed 4 traps. Never caught it, never saw any other evidence. Suspect he left the camper and then we moved it.
Now, if you guys want to here the story about the rat on my sailboat....... (Think Caddyshack)
A friend caused damage to the teak interior of his boat trying to kill a rat at 2AM with a butcher knife.
