SWharton Posted July 26, 2015 Report Share Posted July 26, 2015 This morning for the 2nd time I got the Blue Screen, it stayed around long enough so could write down the problem. Bad Pool Caller Error. Did a google lookup and basically said I probably had corrupted drivers and run the Intel driver update. I did that. If I get the blue screen again does anyone know how I can keep it up long enough to read it and make notes? Link to comment Share on other sites More sharing options...
TheDuke Posted July 26, 2015 Report Share Posted July 26, 2015 This article has all theinfo you can use. http://www.howtogeek.com/222730/how-to-find-out-why-your-windows-pc-crashed-or-froze/ Keep in mind that almost all if not all BSD's are cause by hardware/driver issues. Link to comment Share on other sites More sharing options...
chuckbear Posted July 26, 2015 Report Share Posted July 26, 2015 What OS are you running? There was a recent MS update that screwed up some drivers for Windows 10, maybe others. Chuck Chuck and Susan 1999 Fleetwood Bounder 34 Triton V10 on Ford Chassis Link to comment Share on other sites More sharing options...
docj Posted July 26, 2015 Report Share Posted July 26, 2015 You can use Blue Screen View http://download.cnet.com/BlueScreenView/3000-2094_4-10965136.html or a similar program to analyze the memory dump so you can figure out what caused the BSOD. For example, I've been running Connectify full-time for the past month and have noticed that it occasionally messes up my laptop's wifi driver. At least knowing the cause allowed me to check to make sure the driver I'm using is the most current one for my wifi adapter. Sandie & Joel 2000 40' Beaver Patriot Thunder Princeton--425 HP/1550 ft-lbs CAT C-12 2014 Honda CR-V AWD EX-L with ReadyBrute tow bar/brake systemWiFiRanger Ambassador Follow our adventures on Facebook at Weiss Travels Link to comment Share on other sites More sharing options...
SWharton Posted July 26, 2015 Author Report Share Posted July 26, 2015 Thanks all. I am running W7, waiting for 10 to shake out. I just ran Blue Screen View and nwifi.sys was the problem. I will do some research on that. Thanks for all the leads. Link to comment Share on other sites More sharing options...
chuckbear Posted July 26, 2015 Report Share Posted July 26, 2015 Have you added and new hardware, installed new drivers or updated any software just prior to your problem starting? If so, you might need to uninstall or remove what you have added and try again. You can also do a System Restore to a date before the problem started. Chuck Chuck and Susan 1999 Fleetwood Bounder 34 Triton V10 on Ford Chassis Link to comment Share on other sites More sharing options...
SWharton Posted July 26, 2015 Author Report Share Posted July 26, 2015 I uninstalled all new software initially. I have now run sfc /scannow and will reboot to see what happens over the next few days. Link to comment Share on other sites More sharing options...
