bigredhdt Posted July 19, 2015 Report Share Posted July 19, 2015 About every 4th time I start my truck I get low oil warning. The oil is well within the full level. Anyone has any luck troubleshooting this? BTW looks like you have to drop the oil pan to change the level sensor. Link to comment Share on other sites More sharing options...
SunJuniper Posted July 22, 2015 Report Share Posted July 22, 2015 which motor? you dont have your signature filled out with what truck/motor/trans you have so its hard to know where to point you first. Fulltimer Class of 2007 1998 Volvo VNL64T610 Detroit Series 60 12.7 470HP/1650TQ Eaton 18spd 228"WB Tandem2006 40' ToyHauler 3 slides and a 14' Toybox Link to comment Share on other sites More sharing options...
bigredhdt Posted July 31, 2015 Author Report Share Posted July 31, 2015 Ved12 Link to comment Share on other sites More sharing options...
SIBERNUT Posted July 31, 2015 Report Share Posted July 31, 2015 Low LEVEL, or low PRESSURE ? I don't know if a VED12 reads level or not. 2000 Volvo 635 A/S, N-14 Cummins"The Phoenix"'03 KA 38KSWB http://s918.photobucket.com/user/sibernut/library/?sort=6&page=1Furkids- Sibe's CH. Sedona & Tseika Link to comment Share on other sites More sharing options...
Shallow Draft Posted July 31, 2015 Report Share Posted July 31, 2015 My D12 did the same. Said it was 2 quarts low. Checking the oil on dipstick showed it was OK. I did add some and it seemed to solve the problem. Since I changed oil last time it has not happened. 2004 Volvo 630, Freedomline, Rear view camera, Max Brake, Jackalopee, 38 ft 4 horse LQ Platinum, 40ft Jayco Talon toy hauler Http:/www.flickr.com/photos/shallow_draft/ Https://flic.kr/p/fqhyAN You are not lost if you don't care where you are!! Link to comment Share on other sites More sharing options...
phoenix2013 Posted July 31, 2015 Report Share Posted July 31, 2015 Had the same problem on a Cummins N14. Pressure was so-so and once a while the low oil LED would come on. Problem old oil. Changed the oil, pressure went up substantially, low level light never came on since. Link to comment Share on other sites More sharing options...
