DJW Posted March 13, 2015 Report Share Posted March 13, 2015 We bought Linda a New 3rd Gen iPad to replace her 2nd Gen which we are going to give to our Daughter-in-law to replace the one our Grand Daughter dropped. What is the best way to transfer all of Linda's stuff from her old iPad to her new iPad? Dennis Link to comment Share on other sites More sharing options...
Chad Heiser Posted March 13, 2015 Report Share Posted March 13, 2015 Do you have a laptop or desktop computer with iTunes? If you do then sync your old iPad to iTunes. Then connect the new iPad and restore it from the sync file (basically, iTunes will ask the first time you connect the new iPad if it is replacing an existing device and will prompt you through the process). If you do not have a desktop or laptop, you can sync everything between all your devices with iCloud as well. I don't use iCloud to do this, so I can't give you the exact steps, but a google search should be able to find the proper steps easily enough. Link to comment Share on other sites More sharing options...
ed6713 Posted March 13, 2015 Report Share Posted March 13, 2015 Your "old" iPad is most likely backed up using iCloud automatic backup. That's the easiest way to do things. When you get your new iPad, as part of the initial setup process, it will ask if you want to install all of the settings used by the "old" iPad. Let's say the "old" iPad was named "Linda" when backed up using iCloud. Tell the setup screen to load "Linda" settings. Easy. The setup menus will walk you through the process. Just before you setup the new one, back up the old. That way you will have the most current settings. Link to comment Share on other sites More sharing options...
DJW Posted March 13, 2015 Author Report Share Posted March 13, 2015 Thanks guys I went through iTunes and it was like a walk in the park. Dennis Link to comment Share on other sites More sharing options...
DJW Posted March 14, 2015 Author Report Share Posted March 14, 2015 Ok, when we did the old iPad backup to the laptop via iTunes we thought the photos on the old iPad were backed up as we did not realize that the photos should be done separately . So when we went to do the restore to the new iPad we thought the old photos from the old ipad were on the laptop. Then we chose Sync Photos selected folders from ITunes. So iTunes went into and took all the pictures folders from the C Drive and downloaded them to the new iPad. How do I get rid of the folders that iTunes downloaded to the new iPad? The iPad will not allow us to delete individually or by folder. Help Please Dennis Link to comment Share on other sites More sharing options...
DJW Posted March 14, 2015 Author Report Share Posted March 14, 2015 Funny thing, Linda's new iPad has Siri voice so I asked her and she told me how to do it and it is done. Dennis Link to comment Share on other sites More sharing options...
