bigredhdt Posted February 11, 2015 Report Share Posted February 11, 2015 I have a Volvo vnl 630 2007. In reading the Volvo service information for air troubleshooting, they reference a fitting that can be used to air up the system from an off board compressor. Anyone know where to connect this? Link to comment Share on other sites More sharing options...
AllenF Posted February 11, 2015 Report Share Posted February 11, 2015 When I worked on my air system at the shop I removed the drain fitting down near the steps. I installed a male quick connect from the end of an air hose. I then took a male and a female plug to mate the hose end to the tank. It took less than 30!seconds to fully air up the system. Make sure to either regulate the shop air at 120 psi or remove the air hose in time. Our shop air is set at 180, otherwise you will pop the relief valve. Link to comment Share on other sites More sharing options...
Shallow Draft Posted February 11, 2015 Report Share Posted February 11, 2015 I have an 04 Volvo and I can air it up from a fitting on the drivers side at eye level just inboard of the hood wear block 2004 Volvo 630, Freedomline, Rear view camera, Max Brake, Jackalopee, 38 ft 4 horse LQ Platinum, 40ft Jayco Talon toy hauler Http:/www.flickr.com/photos/shallow_draft/ Https://flic.kr/p/fqhyAN You are not lost if you don't care where you are!! Link to comment Share on other sites More sharing options...
bigredhdt Posted February 11, 2015 Author Report Share Posted February 11, 2015 Shallow draft,What type if fitting is installed? What motor do you have? Link to comment Share on other sites More sharing options...
MrSeas Posted February 11, 2015 Report Share Posted February 11, 2015 Schraeder valve here: http://www.amazon.com/gp/product/B003X5Q8LY/ref=oh_aui_search_detailpage?ie=UTF8&psc=1 D-2 Governor On my 2005 Volvo with a Cummins ISX my air governor is located on drivers side firewall just inboard of the hood wear block as mentioned in a previous post. I added the schraeder valve to an empty port marked RES. Just connect shop air and air up your tanks. I do use a water separator/filter between my compressor and the truck to keep contaminants and moisture down since this air goes straight to the tanks. Good luck. Scott Link to comment Share on other sites More sharing options...
Shallow Draft Posted February 11, 2015 Report Share Posted February 11, 2015 Shallow draft,What type if fitting is installed? What motor do you have? Normal tire inflater. Schrader I think Volvo D12 2004 Volvo 630, Freedomline, Rear view camera, Max Brake, Jackalopee, 38 ft 4 horse LQ Platinum, 40ft Jayco Talon toy hauler Http:/www.flickr.com/photos/shallow_draft/ Https://flic.kr/p/fqhyAN You are not lost if you don't care where you are!! Link to comment Share on other sites More sharing options...
rickeieio Posted February 12, 2015 Report Share Posted February 12, 2015 <<On my 2005 Volvo with a Cummins ISX my air governor is located on drivers side firewall just inboard of the hood wear block as mentioned in a previous post. I added the schraeder valve to an empty port marked RES. Just connect shop air and air up your tanks. >> Good luck. Scott Did the same thing on my Mack a few weeks ago. Makes it a lot easier to air up the truck so I don't smoke up the shop building air. KW T-680, POPEMOBILE Newmar X-Aire, VATICAN Lots of old motorcycles, Moto Guzzi Griso and Spyder F3 currently in the front row Young enough to play in the dirt as a retired farmer. contact me at rickeieio@yahoo.com Link to comment Share on other sites More sharing options...
bigredhdt Posted February 14, 2015 Author Report Share Posted February 14, 2015 Thanks everybody. Nevere thought to look on the governor. There was on there already, hope that's not a bad sign. What is the consensus regarding filling from a portable compressor? Should I have a dryer/filter or just a dirt/water filter? Link to comment Share on other sites More sharing options...
