Stand By Electrical Power
matt5ash
That is actually fairly low as far as “phantom” draws go in an RV.  Unless you completely disconnect the battery bank from the RV, there are almost always little phantom draws pulling power (even when nothing appears to be turned on).  An example is the LP gas detector or a clock memory or other similar devices.
My First Solar Install Thread
The LP detector in our 2017 Class C draws amperage when the battery relay is off and shore power disconnected.  Dealership said that it is required now (safety reasons) for the LP detectors to be powered even when the battery relay is off and shore power disconnected.
Richard "Doc" Strait, USN Retired
2017 Coachmen Leprechaun 319MB
Point of Contact for the Military, Veterans, and Gold Star Families BOF
On 5/13/2020 at 6:20 PM, Lou Schneider said:
4 watts is 0.33 amps at 12 volts.  It will take 151 hours (6.3 days) to drain a single 100 amp-hour battery to the 50% charge level.  Not too bad.
thanks !! I guess that a couple of 100 AH lithium batteries will take even longer
Lithium batteries can be drained to their full capacity, so figure a pair of 100 amp-hour lithiums can deliver 4 times as much usable power as a single 100 AH lead acid battery that should only be drained to the 50% level.
Edited by Lou Schneider
