RWeigant Posted May 6, 2020 Report Share Posted May 6, 2020 Have a Colman AC in our 2013 American Tradition. The problem is the fan on top broke one of the blades off and that made the motor come loose. I got a new fan, but the brackets that hold the fan motor the bottom of the housing has come loose from the bottom. I can't figure how to reattach it without removing the AC from the roof. It has 3 arms that sit on rubber 1/2" pads. The screws that hold this are inserted from the bottom. Can't reach the bottom. Any ideas? Quote Link to comment Share on other sites More sharing options...
Ed ke6bnl Posted May 6, 2020 Report Share Posted May 6, 2020 Check out thread Inserts, may work for this. Even Harbor Freight has A cheap set. Quote 2000 National RV Sea Breeze 5th wheel 30ft. So.California 1950 F1 street rod 1949 F1 stock V8 flathead 1948 F6 350 chevy/rest stock, no dump bed shortened frame. 1953 chevy 3100 AD for 85 S10 frame 1968 Baha Bug with 2.2 ecotec motor 170 hp, king coil-overs,etc 1970 Baha Bug wihg 2332cc, King coil overs and everything else there is. 1998.5 Dodge 2500 4x4 Cummins, turbo, trans, injectors, lockers, bigger turbo,edge EZ upgrades for towing 35" BFG's, air dog lift pump etc. Link to comment Share on other sites More sharing options...
RWeigant Posted May 6, 2020 Author Report Share Posted May 6, 2020 The plastic I'm dealing with is very thin, about 1/16". I could use these, but a second insurance would be nice. I thought of drilling 2 holes of each side and adding a tie strip around the leg. Still thinking. Quote Link to comment Share on other sites More sharing options...
Ed ke6bnl Posted May 6, 2020 Report Share Posted May 6, 2020 Sure, pop rivet a 1/8plate and then thread insert Quote 2000 National RV Sea Breeze 5th wheel 30ft. So.California 1950 F1 street rod 1949 F1 stock V8 flathead 1948 F6 350 chevy/rest stock, no dump bed shortened frame. 1953 chevy 3100 AD for 85 S10 frame 1968 Baha Bug with 2.2 ecotec motor 170 hp, king coil-overs,etc 1970 Baha Bug wihg 2332cc, King coil overs and everything else there is. 1998.5 Dodge 2500 4x4 Cummins, turbo, trans, injectors, lockers, bigger turbo,edge EZ upgrades for towing 35" BFG's, air dog lift pump etc. Link to comment Share on other sites More sharing options...
Ray,IN Posted May 7, 2020 Report Share Posted May 7, 2020 Bite the bullet, buy a new air conditioner gasket, remove the AC from the opening, make required repairs, use new gasket and replace AC unit. NEVER reuse the old gasket. Quote 2000 Winnebago Ultimate Freedom USQ40JD, ISC 8.3 Cummins 350, Spartan MM Chassis. USA IN 1SG retired;Good Sam Life member,FMCA ." And so, my fellow Americans: ask not what your country can do for you--ask what you can do for your country. John F. Kennedy 20 Jan 1961 Link to comment Share on other sites More sharing options...
rynosback Posted May 7, 2020 Report Share Posted May 7, 2020 3 hours ago, Ray,IN said: Bite the bullet, buy a new air conditioner gasket, remove the AC from the opening, make required repairs, use new gasket and replace AC unit. NEVER reuse the old gasket. I agree. Quote 2015 Ram 3500 RC DRW CTD AISIN 410 rear 2016 Mobile Suites 38RSB3 Link to comment Share on other sites More sharing options...
Wrknrvr Posted May 7, 2020 Report Share Posted May 7, 2020 If I remember correctly( Airxcel which makes those units) told me to make sure that the ac unit is not touching anything that would put stress on that base. Yes I have seen a few of those problem. I had one that the fan broke which made the motor vibrate and broke all the mounts. When I looked in the motor was laying on its side. You may use some goop which is a strong glue that never gets real hard. But is really tough. It may assist in trying to mount the motor again. Safe Travels, Vern Quote Link to comment Share on other sites More sharing options...
RWeigant Posted May 8, 2020 Author Report Share Posted May 8, 2020 What I did come up with is I bought some 2" thin plates from HD and welded a threaded stud from behind the plate. Then I epoxied the plate where the old screws were and lined them up to the motor studs. The rubber isolation made I had to drill out to except the stud. So far so good. After I got it all together, I notice the fan was touching the cover. The cover was caved in from the sun heat. I hot glued sone hard foam strips on top of the box, or you could have done the same under the plastic cover. Quote Link to comment Share on other sites More sharing options...
