Mtn.Mike Posted November 16, 2017 Report Share Posted November 16, 2017 I have a 2004 Holiday Rambler Endeavor and just noticed that the front cover for the generator was out of alignment so I attempted to tighten the screws that hold the cover on. I discovered that under the fiberglass they had used wood and the wood was rotten. I only have one solid screw and the others are removable by hand. How can I attach the screws without drilling and running carriage bolts to the outside of the cover which will then show from outside? 2004 Holiday Rambler Endeavor 40 PDQ being pushed by a 2013 MX-5 Miata. Link to comment Share on other sites More sharing options...
lenp Posted November 17, 2017 Report Share Posted November 17, 2017 Could you get the wood out of the existing fiberglass and then install fresh wood followed by some new fiberglass (all on the inside)? This would require some fiberglass work but it is not that hard to do. Lenp USN Retired 2002 Winnebago Ultimate Freedom 2012 F150 4x4 2018 Lincoln MKX 2019 HD Ultra Limited Link to comment Share on other sites More sharing options...
Wrknrvr Posted November 17, 2017 Report Share Posted November 17, 2017 Dig the wood out and clean it extremely good. Sand the old glass where the wood was and then fill it with glass and resin Vern Link to comment Share on other sites More sharing options...
ARGO Posted November 17, 2017 Report Share Posted November 17, 2017 Try "Git-Rot" on it 1st. It is a penetrating resin that will form a better bond to the wood than regular resin. Then fill. You'd have to see the movie to understand.......... Link to comment Share on other sites More sharing options...
folivier Posted November 17, 2017 Report Share Posted November 17, 2017 Look at this website: rotdoctor.com CPES, clear penetrating epoxy would be the first product. The wood cells absorb this thin clear liquid and once cured can't absorb water and can't rot further. Then fill with this Fill-It epoxy filler. Then drill a pilot hole and install new stainless screws. Done. Back on the road again in a 2011 Roadtrek 210P 2011 Tahoe 4x4, 2006 Lexus GX470, 2018 Ranger XP1000, 2013 RZR 570LEhttp://finallynewellin.blogspot.com/ Link to comment Share on other sites More sharing options...
