burnsgd2 Posted October 7, 2017 Report Share Posted October 7, 2017 We own a 2000 Monaco Windsor and recently the fresh water pump quit working. We replaced it with a new one yesterday and to our dismay it still does not work. We have checked the fuses. The person that installed it checked the voltage on the wires to the to pump and there is none. No sure what to do next. Any ideas? Link to comment Share on other sites More sharing options...
Ranger Smith Posted October 7, 2017 Report Share Posted October 7, 2017 If you have more than 1 switch that controls the pump there is a pump controller module somewhere. That is either bad or the 12 volts to it is dead Steve and Joy Amateur Radio Operator WZ1T . . . Flex 6600 M, Flex PGXL, Flex TGXL, 2014 Itasca Suncruiser 38Q . . . Lincoln MKX Toad The Kids . . . Yogi the Yorkie passed 10/20/2018. . . Cookie the Chihuahua passed 11/30/2017 . . . Cooper the Aussie Doodle passed 3/10/2020 Abbie and Abel the Doodles . . . Brother and Sister Born 02/02/2020 . . . Lucy the Yorkie . . . and Axel . . .The Bernie Doodle Where We Are Now Link to comment Share on other sites More sharing options...
burnsgd2 Posted October 7, 2017 Author Report Share Posted October 7, 2017 ok thanks. I Will research where that controller module might be. Link to comment Share on other sites More sharing options...
Devilishjim Posted October 7, 2017 Report Share Posted October 7, 2017 switch itself might be bad/ check for power at the switch Jim Spence 2000 Dodge 3500 1 ton QC 4x4 dually 5.9 diesel LB BD exhaust brake, 6 spd manual trans 34CKTS Cedar Creek 5er, Trail-Air hitch Link to comment Share on other sites More sharing options...
Kirk W Posted October 7, 2017 Report Share Posted October 7, 2017 Do you own a voltmeter that you can use to check the voltage with? If you do, go back to the switch and check where power connects to it. Does your water pump have more than one on/off switch? There are several ways they can be wired but if there are more than 2 switches, there must be a control somewhere. The circuits are not complicated but some basic knowledge of dc electricity is helpful. If you still have the first pump, you might want to use a pair of jumpers from the battery to test it as quite likely it is still good and the loss of power is the cause of its failure. Good travelin !...............KirkFull-time 11+ years...... Now seasonal travelers.Kirk & Pam's Great RV Adventure Link to comment Share on other sites More sharing options...
oldjohnt Posted October 7, 2017 Report Share Posted October 7, 2017 Good advice above. Basically if the fuse in the DC distribution panel is okay and the branch circuit wiring is okay there should be 12 volts getting to the water pump On/Off Switch (many have a pilot light to show when its on, if it has but its not lit when on, switch or supply to it must be bad/open) and then if ON there should be 12 volts (with respect to the ground wire) to the pump area HOWEVER the hot wire goes thru a pressure switch and ONLY sends power to the pump motor itself when pressure drops and the pump needs to run. If you don't have a simple DC Voltmeter one of those cheap 6/12 volt test lamps should be all you need to check for 1) Power to the Switch,,,,,,,,,,,,2) Power out of the switch when ON,,,,,,,,,,,,3) Power to the pump area,,,,,,,,,,,,,,4) Power to the pump motor itself when its needed due to low pressure. If that dude told you no power TO the pump, its likely a bad fuse or a broken wire to the switch or a bad switch or a bad wire from switch to the pump. Start at the switches INPUT then OUTPUT if on then down at the pump area ahead of and before the pressure switch You can do this, its not near as hard as troubleshooting a hot water heater lol John T Currently full timing, we handed over the farm and home keys one hour ago Link to comment Share on other sites More sharing options...
Darryl&Rita Posted October 7, 2017 Report Share Posted October 7, 2017 Be aware, at least one pump remote switches the ground side of the circuit. I have been wrong before, I'll probably be wrong again. 2000 Kenworth T 2000 w/N-14 and 10 speed Gen1 Autoshift, deck built by Star Fabrication 2006 smart fourtwo cdi cabriolet 2007 32.5' Fleetwood QuantumPlease e-mail us here. Link to comment Share on other sites More sharing options...
oldjohnt Posted October 8, 2017 Report Share Posted October 8, 2017 19 hours ago, Darryl&Rita said: Be aware, at least one pump remote switches the ground side of the circuit. Darryl, Ive seen RV appliances switched on the NEG side, no idea if it was factory original or not??? I always switch on the POS side myself. Its unlike household 120 VAC where the UNgrounded HOT conductor is switched as its 120 VAC with respect to Mother Earth,,,, as well as the Equipment Ground Buss,,,, and Equipment GroundING Conductors, which are bonded to the outer metallic conductive frames of tools and appliances,,,, as well as the GrounDED Conductor (Neutral). John T Link to comment Share on other sites More sharing options...
Darryl&Rita Posted October 8, 2017 Report Share Posted October 8, 2017 I had to dig into the memory bank for this one. Take a look at the wiring diagram for this pump controller:Intellitec Page 2 gives the wiring diagram for the whole system, including the switched ground. ETA: This link will also give the OP an idea of what they're looking for. I have been wrong before, I'll probably be wrong again. 2000 Kenworth T 2000 w/N-14 and 10 speed Gen1 Autoshift, deck built by Star Fabrication 2006 smart fourtwo cdi cabriolet 2007 32.5' Fleetwood QuantumPlease e-mail us here. Link to comment Share on other sites More sharing options...
Kirk W Posted October 8, 2017 Report Share Posted October 8, 2017 35 minutes ago, Darryl&Rita said: Take a look at the wiring diagram for this pump controller:Intellitec Thanks for that link. I seem to have lost it somewhere in my travels. One thing to note that should indicate the use of one of those controllers is the fact that in this case, that pump switch is only momentary, and spring returned to open, where a single switch is typically manually closed and opened. Good travelin !...............KirkFull-time 11+ years...... Now seasonal travelers.Kirk & Pam's Great RV Adventure Link to comment Share on other sites More sharing options...
