sthroop Posted November 24, 2023 Report Share Posted November 24, 2023 Hello! I got a crack in the fresh water tank of my 2001 Atlantis. I would like to pull the tank out to repair, but I need to disconnect these pipes first. I have been working on them for a few minutes without much success. Can anyone tell what type of pipe fittings these are and if I can safety disconnect and reconnect them? Thanks! Quote Link to comment Share on other sites More sharing options...
Kirk W Posted November 25, 2023 Report Share Posted November 25, 2023 HOW TO REMOVE PEX COPPER CRIMP RING article and/or the video HOW TO REMOVE PEX COPPER CRIMP RING I hope that you find this helpful. Quote Good travelin !...............KirkFull-time 11+ years...... Now seasonal travelers.Kirk & Pam's Great RV Adventure Link to comment Share on other sites More sharing options...
GeorgiaHybrid Posted November 25, 2023 Report Share Posted November 25, 2023 (edited) You will be a lot better off to make a cut in both pex tubes about 6" above the fittings and put a splice in them when you reinstall the tank. For the splice, you can use a sharkbite fitting, a stainless steel crimp ring (my preference) or a crimped copper ring. Edited November 25, 2023 by GeorgiaHybrid Quote 2017 Kenworth T6802015 DRV 38RSSA Elite Suites2016 Smart Prime Link to comment Share on other sites More sharing options...
Wrknrvr Posted November 25, 2023 Report Share Posted November 25, 2023 I would not try to remove the crimp ring. That can be interesting to do. I have done it. But cutting them where you can splice them would be much easier. And if you use a shark bite type connector, you can remove them again with ease. The shark bite fitting has a o’ring to seal the pipe. The only time I have had a problem with this type of fitting, is if the pipe has stamped markings on them. Mose has printed lettering on them. Quote Link to comment Share on other sites More sharing options...
