D&J Posted October 22, 2023 Report Share Posted October 22, 2023 7 minutes ago, etu said: I owe y’all a belated update. Even though I had cleaned the coil with water I went ahead and cleaned the roof top coil with a professional grade coil cleaner. It foamed up like shaving cream and boiled out a lot of dark residue. I repeated the cleaning and now I’m getting 18-20 degree differential. unit cycles on and off after replacing the control kit so I’m ok I think. thank you for all the advice and replies. You mean the service person you had look at it never when on the roof and checked the condenser coil, never call him again. The very first thing that should be checked is the condenser. The cover has to be removed because the way the air flows in the sides and out the back so you can't see if the coil is plugged. 18 to 20 differential is perfect. Denny Quote Denny & Jami SKP#90175 Most Timing with Mac our Scottie, RIP Jasper our Westie 2013 F350 SC DRW 6.2 V8 4.30 Gears 2003 HH Premier 35FKTG Home Base Nebraska Link to comment Share on other sites More sharing options...
Kirk W Posted October 22, 2023 Report Share Posted October 22, 2023 24 minutes ago, etu said: I repeated the cleaning and now I’m getting 18-20 degree differential. The service manuals usually say that between 18° & 24° is the normal range so you should be good, particularly if you have the blower on high cool. Quote Good travelin !...............KirkFull-time 11+ years...... Now seasonal travelers.Kirk & Pam's Great RV Adventure Link to comment Share on other sites More sharing options...
