Susan Jones Posted December 14, 2022 Report Share Posted December 14, 2022 We're going to be traveling to a very cold climate and we don't know what to do to winterize our travel trailer. Any advice? Quote Link to comment Share on other sites More sharing options...
ms60ocb Posted December 14, 2022 Report Share Posted December 14, 2022 Any details on your travels, are you planning to stay in it as you travel. What are some details of your travel trailer, Make, Model, Age, slides, will help with needs. Some will drain everything and blow out the lines, other may also flush with the RV antifreeze including drain traps ( My choice). Clay Quote Clay & Marcie Too old to play in the snow Diesel pusher and previously 2 FW and small Class C Link to comment Share on other sites More sharing options...
Kirk W Posted December 14, 2022 Report Share Posted December 14, 2022 If you are staying in the trailer, leave the furnace running while on the road. I usually set ours to about 50° that will keep everything from freezing but I'd also keep the water heater on. If you won't be spending the night and/or if you have plumbing that is exposed to the weather, then you do need to winterize and here is a video to help you understand what is needed. Quote Good travelin !...............KirkFull-time 11+ years...... Now seasonal travelers.Kirk & Pam's Great RV Adventure Link to comment Share on other sites More sharing options...
franco-bolli Posted December 15, 2022 Report Share Posted December 15, 2022 Adding on to the advice that Kirk provided while on the road, You may wish to turn them all off before you enter the fueling station, particularly if you're going to get gas. Don't make an ash of yourself in front of a lot of strangers by setting the place on fire. Some states have restrictions for transporting propane through tunnels, like NY, and Maryland, and New Jersey. I found this on tripsavvy.com "If you’re traveling from Illinois to Iowa, route around the bridge between Fulton, IL, and Clinton, IA. Trailers are prohibited on that bridge. If you have propane tanks (don’t we all?) you cannot pass through the Baltimore Harbor Tunnel or Fort McHenry Tunnel in Maryland. In Virginia, you’re limited to two portable bottled gas tanks of 45 pounds with valves closed in the Hampton Roads Bridge Tunnel, Chesapeake Bay Bridge Tunnel and the Norfolk-Portsmouth Tunnel. " Safe Journeys Quote +++++++++++_____________________________________+++++++++++ 2021 Ram 3500 2017 Arctic Fox 25W(to be traded??) HAM guy (Ke7FIX), photography, woodworking (mostly sawdust), Electronics Technician, USAF DAV Going where everyone has gone before Link to comment Share on other sites More sharing options...
