2000 Suncruser Basement Heat Pump
If you only need half the cooling power, no.
I had a basement heat pump that only used one compressor for the first 3 months after installing because a "jumper wire" wasn't securely fastened. Sure worked better for the short time it lived after, but I'm much more happy with the mini split I had it replaced  with.
Knowing the brand of unit is probably more important than the brand of RV.
Rod
2007 Honda GL 1800
The Gold Volvo is still running and being emptied in July.
sent you a pm
2007 Honda GL 1800
If the temperature difference between the thermostat and indoor temperature is less than 4° only #1 compressor will run. If #1 cannot reach/maintain thermostat set temperature #2 compressor turn on.
IF you only want to run #1, turn of the 120V breaker that controls the #2 compressor.
Note: #1 is the primary compressor and must be running for #2 to run, thus turning off #2 breaker. Do you know the model# of your Coleman Mach 24,000btu unit?
I appeciate all the comments. But my questions is more like will just running one compressor all the time hurt the system?
Still seeing Places we have never seen before and others that we thought we would never see again!
homelesshartshorns | Trying to spend the last Dollar on the Last Day! (wordpress.com)
George Hartshorn | Facebook
Nope, no harm to anything. #1 compressor should maintain set temperature IF you start out in the morning before set temperature is reached.
