Vladimir Posted December 6, 2021 Author Report Share Posted December 6, 2021 I was NOT impressed with their location app. The "best" location I did first, and was told it was a great location. I then walked around the meadow looking at other spots. The app was correct in the sense that none were better than the initial site. However, I came back to the first location and did it again. That time, I was told, not good enough. IF you can find someone with a dish (in YOUR STARLINK CELL LOCATION) it is fairly easy to just set up the dish and see how it works!! You can easily set your dish 300 feet from your home. Just use a 200 foot router wire. My neighbor did that and it worked fine. I am using a 125 foot router run. You do want to keep the CAT line between the dish and the power brick to 100 feet, as I understand it. Quote Vladimr Steblina Retired Forester...exploring the public lands. usbackroads.blogspot.com Link to comment Share on other sites More sharing options...
docj Posted December 6, 2021 Report Share Posted December 6, 2021 (edited) On 12/6/2021 at 11:55 AM, Vladimir said: I was NOT impressed with their location app. The "best" location I did first, and was told it was a great location. I then walked around the meadow looking at other spots. The app was correct in the sense that none were better than the initial site. I agree that the location app is fairly useless when you're looking to find a spot to use for siting the dish, but once you have sited it, you can get a reasonable perspective for how much obscuration you are getting. I've attached a screenshot showing where I have a small blockage in one particular direction. Edited January 16, 2023 by docj Quote Sandie & Joel 2000 40' Beaver Patriot Thunder Princeton--425 HP/1550 ft-lbs CAT C-12 2014 Honda CR-V AWD EX-L with ReadyBrute tow bar/brake systemWiFiRanger Ambassador Follow our adventures on Facebook at Weiss Travels Link to comment Share on other sites More sharing options...
Vladimir Posted December 7, 2021 Author Report Share Posted December 7, 2021 7 hours ago, docj said: I agree that the location app is fairly useless when you're looking to find a spot to use for siting the dish, but once you have sited it, you can get a reasonable perspective for how much obscuration you are getting. I've attached a screenshot showing where I have a small blockage in one particular direction. Is the light blue....clear sky or obstruction?? Quote Vladimr Steblina Retired Forester...exploring the public lands. usbackroads.blogspot.com Link to comment Share on other sites More sharing options...
docj Posted December 8, 2021 Report Share Posted December 8, 2021 On 12/6/2021 at 8:00 PM, Vladimir said: Is the light blue....clear sky or obstruction?? The light blue is clear sky, the small red spot is obstruction. Quote Sandie & Joel 2000 40' Beaver Patriot Thunder Princeton--425 HP/1550 ft-lbs CAT C-12 2014 Honda CR-V AWD EX-L with ReadyBrute tow bar/brake systemWiFiRanger Ambassador Follow our adventures on Facebook at Weiss Travels Link to comment Share on other sites More sharing options...
Vladimir Posted December 8, 2021 Author Report Share Posted December 8, 2021 14 hours ago, docj said: The light blue is clear sky, the small red spot is obstruction. I can't see your obstructions. However, my obstruction is ALMOST exactly your CLEAR SKY view. My obstruction does extend a bit more to the south. Mine are Ponderosa Pine trees. I get 100 to 200 Mbps in that location. Hope this helps. Quote Vladimr Steblina Retired Forester...exploring the public lands. usbackroads.blogspot.com Link to comment Share on other sites More sharing options...
