Winterizing
Herb
 Share
You may have a bad valve  at the pump suction as I believe that it is designed to change the pump suction from the tank to your antifreeze jug? It could also be that if you have a potable water tank fill valve that fills the tank from the city water connection and that is open to fill the tank, it would also allow the pump to push antifreeze from your supply, through the fresh water system and past that open tank fill valve to the top of the fresh water tank. If that happens it would also use far more antifreeze than normal.
 Share
RV Cable Grip
RV Cable Grip
RV Air.
